Red Hat Kernel Compatible Support
ISR has been successfully tested and is compatible with the Red Hat kernel compatible with Oracle Linux 7.6. Red Hat Compatible Kernel is configured at boot time selections.
To enable RHEL:
- Open a terminal for the ISR components.
- Enter reboot.
- Select
Oracle Linux
server with Linux 7.6 and press Enter.
