PreviousNextJavaScript must be enabled to correctly display this content
Testing the RMC Converter
Test that the RMC is converting properly by playing a
G.729 recording through the
ISR Dashboard.
To test the RMC converter:
Open your Internet
Web browser.
Enter the IP
address of the
ISR Dashboard. For
example:
http://172.54.66.7
The Login page displays.
Enter your
credentials in the
Email and
Password fields.
The default user name and password are:
User name:
isradmin@acmepacket.com
Password: admin123
The following page displays.
From the Main Menu,
click
Recordings. The
Select a recording
that has a file name in the format .rpdd and then click the Play icon.
If the RMC conversion process was successful
(recording is converted from a ".rpdd" file to a .wav file), the recording
opens and an audible playback of the recording is heard.
If the RMC conversion process was unsuccessful, an error message
displays.
Converter logs can be found on the RSS host in
/opt/isr/logs/converter/ for troubleshooting.
