Configuring Circular Replication
To configure circular replication:
Create a
replication user on each MySQL instance.
Using the MySQL command line client or a GUI tool such as MySQL Workbench, enter the following on the PRIMARY index:
GRANT REPLICATION SLAVE ON *.* TO 'repl'@'<secondary index IP address>' IDENTIFIED BY '<your_password>';Using the MySQL client again, enter the following on the SECONDARY index:
GRANT REPLICATION SLAVE ON *.* TO 'repl'@'<primary index IP address>' IDENTIFIED BY '<your_password>'; -
Enable binary
logging on the PRIMARY host.
Log into the
Index Virtual Machine (VM) of the PRIMARY host and shut down the MySQL service
by entering the following:
systemctl stop mysqld
Make a back-up
instance of the file /etc/my.cnf (for example, /tmp/my.cnf), and then edit
/etc/my.cnf by entering the following in the [mysqld] section:
log-bin=Primary1-mysql-bin server-id=1 #Replication increments to avoid primary key auto-increment #collisions for 2 hosts auto_increment_increment=2 auto_increment_offset=1 #Set the db/tables to replicate replicate-do-db=ipcr_db replicate-ignore-table=ipcr_db.log replicate-ignore-table=ipcr_db.heartbeats #Set the master for replication reporting (optional) report-host= secondary host ip address
If copying and pasting directly from this document, ensure there are no erroneous carriage returns impacting the configuration "my.cnf" file formatting. This could prevent MySQL Server from starting properly. -
Make sure the
following lines are in the mysqld section:
binlog-format=mixed slave-skip-errors=1032 sync_binlog=1
Log into the
Enable binary
logging on the SECONDARY host.
Using a secure
shell client (SSH), log into the Index VM of the SECONDARY host. Then shut down
the MySQL service by entering the following :
Make a back-up
log-bin=Secondary2-mysql-bin server-id=2 #Replication increments to avoid primary key auto-increment #collisions for 2 hosts auto_increment_increment=2 auto_increment_offset=2 #Set the db/tables to replicate replicate-do-db=ipcr_db replicate-ignore-table=ipcr_db.log replicate-ignore-table=ipcr_db.heartbeats #Set the master for replication reporting (optional) report-host=primary host address
Make sure the
Using a secure
Start the MySQL
instance on both the PRIMARY and SECONDARY hosts by entering the following:
systemctl restart mysqld
WARNING:
Ensure there are no connections to the ISR Record and Store Server (RSS), and that the Dashboard on both primary and secondary hosts is disabled. To disable the Dashboard via the CLI, issue the following command:systemctl stop puma
To restart the Dashboard via the CLI, issue the following command:systemctl start puma
Using the MySQL
client, check the Master status on the PRIMARY host by entering the following:
mysql> FLUSH TABLES WITH READ LOCK; mysql> SHOW MASTER STATUS;
The following is an example of the output from the above commands.
File Position Binlog_Do_DB Binlog_Ignore_DB Primary1-mysql-bin.000002 98 test manual, mySQL - Make a note of the filename and position values from the output table.
Free the read lock
mysql> UNLOCK TABLES;
Using the MySQL
client, on the SECONDARY host, edit the MySQL replication Slave configuration
using the file and position values from the output in Step 5, and enter the
following using the CHANGE MASTER command:
RESET SLAVE; CHANGE MASTER TO MASTER_HOST='<primary host IP address>', MASTER_USER='repl', MASTER_PASSWORD='example123', MASTER_LOG_FILE='Primary1-mysql-bin.000002', MASTER_LOG_POS=98;
Start the Slaves
& ensure there are no errors in the "MySQL logs" by entering the following:
mysql> START SLAVE;
Check the Master
status on the SECONDARY host by entering the following:
File Position Binlog_Do_DB Binlog_Ignore_DB Secondary2-mysql-bin.000002 98 test manual, mySQL - Make a note of the filename and position values from the output table.
Free the read lock
Using the MySQL
client, on the PRIMARY host, edit the MySQL replication Slave configuration
using the filename and position values from the output in Step 10 (from the
SECONDARY host), and enter the following using the CHANGE MASTER command:
RESET SLAVE; CHANGE MASTER TO MASTER_HOST='<secondary host IP address>', MASTER_USER='repl', MASTER_PASSWORD='example123', MASTER_LOG_FILE='Secondary2-mysql-bin.000002', MASTER_LOG_POS=98; START SLAVE;
The following commands, run on each host, display the current replication status. To improve the formatting, append the command with \G.
mysql>SHOW MASTER STATUS \G mysql>SHOW SLAVE STATUS \G
