Configuring Database Failover To edit the configuration on the ISR API and Archival deployments to include database failover: Using a secure shell (SSH) client, log into the RSS or FACE host/s using a user name and password. To add the secondary database IP address to the API configuration, edit the following file. /var/lib/tomcat/webapps/IsrApi/WEB-INF/web.xml Using the arrow keys to navigate the file and edit the following line with the relevant IP addresses: <context-param> <param-name>connectionString</param-name> <param-value>jdbc:mysql://169.254.1.50,<secondary_host_IP>/ipcr_db</param-value> <description>MsSQLX connection URI</description> </context-param> Save your changes to the file. Restart the application server by performing the following: systemctl restart tomcat If required, verify successful failover between the PRIMARY and SECONDARY servers.
