PreviousNextJavaScript must be enabled to correctly display this content
Upgrading the ISR RSS
This section describes the
ISR RSS upgrade process.
The following examples use <release#> as a placeholder for the appropriate file name you are upgrading to.
Log into the RSS host using the recommended "isradm" user.
Copy the RSS upgrade file "isr-rss-<release#>-upgrade.tgz into the
/opt/isr/releases directory.
Switch to the
root directory by executing the
cd / command.
Delete prior ISR RPM packages to avoid confusion with the current version by executing the following command:
$ sudo rm /opt/isr/releases/isr-*.rpm
Unpack the upgrade file from the
root directory by executing the following command:
sudo tar xzf /opt/isr/releases/isr-rss-<release #>-upgrade.tgz -C /
Run the upgrade script by executing the following command:
sudo /opt/isr/releases/upgradeIsr.sh
Follow the script's prompts and instructions closely.
Verify the updated build upon completion by executing the following command.
yum info isr-rss
If the upgrade is successful, the following information displays.
Repo : installed
Summary : 6.0 20161234-567890 RSS for ISR
Run the configuration script by executing the following command:
sudo /opt/isr/configIsr.sh
Follow any configuration script's prompts and instructions closely to ensure all component configurations are verified and select the
q option to finish.
