Configuring Web Proxy Settings
When internal services in P6 EPPM need to access external web sites, they may need to go through your organization's firewall. You can configure that capability in the Web Proxy settings. P6 uses web proxy settings when it displays Contract Manager portlets that integrate with a Fusion server and when it connects to a Geo Code Provider server.
To set your web proxy settings:
  1. Open the Primavera P6 Administrator.
  2. In the Configurations drop-down list, select your configuration.
  3. In the sidebar select Client Properties.
HTTP Server And Port Override: The HTTP front-end web server and port that P6 clients should use. Use URL format: http[s]://servername[:port], do not include context root. This setting is only necessary if problems are encountered while using a front-end web server proxy.
Related Topics
About the Configurations Tab in the Primavera P6 Administrator
Configuring Localization Settings
Configuring Session Management Settings
Configuring Database Instance Settings for On-Premises
Configuring Thread Pool Settings
Configuring AutoVue without VueLink
Configuring Outside In
Configuring Log Settings
Configuring Client Properties Settings
About Application Settings in the Primavera P6 Administrator
About the Primavera P6 Administrator Services Settings
Configuring P6ProCloudConnect Settings
Configuring GeoCodeProvider Settings
Configuring Integration API Server Settings
About Configuring P6 EPPM Web Services in the Primavera P6 Administrator
Configuring P6 Team Member Settings
Configuring Diagnostics Settings
Copyright © 1999, 2022
Last Published Wednesday, September 21, 2022
