Outside In converts documents uploaded to your content repository into a raster-image file.
To configure Outside In:
- In the Primavera P6 Administrator, do the following:
- Select your configuration.
- In the sidebar, select Document Viewing.
- In the Fonts Directory field, enter the full path to your operating system-specific fonts folder. For example, C:\Windows\Fonts.
Note: You cannot convert documents in languages that do not have a compatible font installed in the Fonts Directory. Before you convert these documents you must install the appropriate language font.
- In the Images Directory field, enter the full path to your Outside In images folder. For example, P6EPPM_HOME\P6\outsidein\ImageExport\Images.
- Navigate to P6EPPM_HOME\P6.
- Run
outsideInConfig.cmd
oroutsideInConfig.sh
(based on your operating system).
