To configure settings for P6 Pro Cloud Connect:
- Open the Primavera P6 Administrator.
- In the Configurations drop-down list, select your configuration.
- In the sidebar select P6ProCloudConnect.
Note: Changes to these settings require you to restart the P6 server.
- In the FetchSize field, enter the maximum number of rows gathered in a database block. The default value is 254. You can enter a value between 0 and 2147483647.
- In the TaskMaxTime field, enter the maximum time allowed for a P6 Pro task to complete. A job consists of one or more P6 Pro tasks. The default value is 5m.
- In the TransactionMaxInactiveInterval field, enter the timeout interval for an inactive session that has a pending database transaction. The default value is 15m.
- In the SessionMaxInactiveInterval field, enter the timeout interval for an inactive session. The default value is 2h.
- In the Mode drop-down menu, you can select Username Token Profile or SAML Token Profile. The default value is Username Token Profile.
