Custom Print Window (General tab)
In the General tab, you can define the general custom print information.
  1. Enter and select values in the following fields:
    Note: Required fields are marked with an asterisk (*) or a star.
    • Name
      Enter a unique name for the custom print, up to 50 characters (use alphanumeric characters, non-ASCII characters, or spaces).
    • Description
      (Optional) Enter a brief description about the custom print up to 250 characters (use non-ASCII characters).
    • Data Source
      Select one of the values from the drop-down list. The list contains all the design objects that support custom print, such as BP names, Space attribute names, and so on.
    • Data Model Type
      This is pre-populated read-only field, based on the selected custom print type. The values, based on the option selected at the time of creating the custom print, can be one of the following:
      Internal
      External
      Internal Multiple
      External Multiple
      Internal or External
  2. Click Apply to continue.
When you click Apply, the system processes the information that you have provided and prepares the custom print for publication. As a result of this process, two additional tabs are added to the Custom Print window that require your input:
See the following topics for details:
Last Published Tuesday, April 15, 2025
