Background Jobs
The system uses jobs to perform various:
- Operations (such as auto creation)
- Scheduled jobs (such as user-defined report [UDR] runs)
- Record creations (from workflow [WF] templates)
- Analytics data pushes (to staging table)
There are several nodes under System Information that provide access to detailed information about background jobs. These nodes, Background Jobs, Background Jobs History, and Background Jobs Statistics, provide certain users and groups (Company Administrators) with access to a list of current jobs and their status, information about jobs that have previously run and what their schedule and impact is for running again, and a more detailed view that lets you filter and sort jobs for a visual cue that helps identify potential issues.
All current jobs (scheduled UDR, scheduled refresh of the attach flow, BP record creation using templates) across the shells are run based on the time zone that you set up in the company Background Jobs module (company-level time zone). In cases where the project time zone is different from the company time zone (for example, facilities based on a certain geographical location), you can go to the shell details (Options tab of the Details window) and from the Time Zone for Background Jobs drop-down list select the desired time zone for all shells in the log. After saving your changes, all the jobs within the shell will use your selected time zone.
In This Section
Setting Permissions for the Background Jobs Nodes
Using the Background Jobs and Background Jobs History pages
Using the Background Jobs Statistics page
Last Published Tuesday, April 15, 2025
