Using the Background Jobs Statistics page
The Background Jobs Statistics log provides the following options:
After you click Run, the page displays a high-level chart that depicts the number of times jobs were run for the selected category. The chart is followed by a sortable list that supplies the detailed information such as the name of the job and how long the job usually takes to run. You can use this information to identify jobs that take a significant amount of time and subsequently determine whether the job can be modified to run more efficiently.
See Also
Background Jobs
Setting Permissions for the Background Jobs Nodes
Using the Background Jobs and Background Jobs History pages
Last Published Tuesday, April 15, 2025
