Setting Permissions for the Background Jobs Nodes
Access to the Background Jobs nodes is controlled by permissions set in the Access Control node.
To set permissions for the Background Jobs nodes:
  1. Go to the Company Workspace tab and switch to Admin mode.
  2. In the left Navigator, select User Administration, and then select Access Control.
  3. In the right pane, expand Administration Mode Access, and then expand System Information.
  4. Under System Information, open and update Background Jobs, Background Jobs History, or Background Jobs Statistics.
    The applicable Module Permission Settings window opens. Here you can add, modify, or remove permission settings.
  5. In the Module Permission Settings window, click the Add button.
  6. In the Permissions Setting for <selected item> dialog box, click the Add Users/Groups button.
  7. In the Users/Groups window, select the intended users or groups and click the Add button.
  8. To return to the Permissions Settings for <selected item> dialog box, click OK.
  9. In the Select Users/Group section of the window, select the users or groups, and then select the applicable level of access for the user or group in the Permissions Settings section.
    • Modify: Lets the selected users and groups create or update settings. This setting includes the View permission.
    • View: Lets the selected users and groups view the applicable log.
    Users/Groups with View permission can view the Background Jobs log without having the ability to edit the time zone. Users/Groups with Modify permission can view the Background Jobs log content and edit the time zone.
  10. To save your selections and return to the Module Permission Settings window, click OK.
  11. Click Apply to save changes and keep the window open, or click OK to save changes and close the window.
See Also
Background Jobs
Using the Background Jobs and Background Jobs History pages
Using the Background Jobs Statistics page
Last Published Tuesday, April 15, 2025
