Updating Company Settings on the Security Tab
To complete the Security tab:
- On the Company Settings page, click the Security tab, and then click Edit.
- In the Files section, complete the applicable fields.
- Maximum File Size Limit (in MB): Enter a size limit number greater than 0 bytes. The default is 100 megabytes (MB).
- File Type Restrictions: Select either Allow or Block, and then use the File Extensions field to specify (whitelist) the types of files that a user can or cannot upload to the system. Enter the file extensions separated with commas.
- In the Hyperlinks section, Allowed URIs field, specify custom Uniform Resource Identifiers (URIs) that can be used by your company.
Valid URIs must start with a letter, but can contain numbers and certain symbols, including:
+,-, and.Note: When a company chooses to allow additional URIs, such as FTP, the system will relax the current validations that are in place for URL standards. However, validations will still be applicable to HTTP and HTTPS URIs, and all other standard requirements, such as the use of double forward slashes (//) are enforced. This might affect records created using auto-create and import functionality.
- In the User Profile section, complete the applicable fields.
- Hide personal information on user profiles: To hide the basic information associated with user profile fields, select this option.
- On mobile app, allow saving user profiles: To display a user's information and let Company or Partner Users store the user's profile on Unifier Mobile for offline use, select either or both of the following options:
- For company users
- For partner users
- In the Proxy Login section, select Allow partner users to grant proxy login to owner company users, if applicable.
- To save your changes, click Save.
See Also
Updating Company Settings on the General Tab
Updating Company Settings on the IP Allowlist Tab
Updating Company Settings on the Support Tab
Updating Company Settings on the Lobby Tab
Last Published Tuesday, April 15, 2025
