Updating Company Settings on the IP Allowlist Tab
To complete the IP Allowlist tab:
- On the Company Settings page, click the IP Allowlist tab, and then click Edit.
- In the IP Allowlist section, select the Allow API access only from below IP addresses option if you want to control the IP addresses from which Representational State Transfer (REST) web service calls are allowed.
Enter IP addresses to allow in the IPv4 and IPv6 fields by using comma (
,) or semicolon (;) separators.You can enter IP addresses in CIDR notation to allow IPs in a particular range. The maximum number of characters allowed for the IPv4 and IPv6 fields is 1000, and duplicate IP addresses will be removed. This Allow IP list filtering can be bypassed if an ‘EXTERNAL_REQUEST' header parameter is not provided in the request or an ‘EXTERNAL_REQUEST' header parameter is set to false.
- To save your changes, click Save.
See Also
Updating Company Settings on the General Tab
Updating Company Settings on the Security Tab
Updating Company Settings on the Support Tab
Updating Company Settings on the Lobby Tab
Last Published Tuesday, April 15, 2025
