Integration Users
Integration user refers to a user who is performing integration by using the REST services.
You (Administrator) can use the Integration Users sub-node (under User Administration node) to view the list of integrated users, create integrated users, and assign or edit permissions for Document Manager and access protocol (Legacy).
To access the Integration Users sub-node:
- Go to the Company Workspace tab and switch to Admin mode.
- In the left Navigator, select User Administration, and then select Integration Users.
The Integration Users log contains the following elements:
Toolbar options
- Create
- Refresh
- Find on Page
Columns
- First Name
- Last Name
- User Name
- Status
- Description
- Auth Type
- Timezone
To view details for a specific user, select the user in the log, click the gear menu (
), and select Open.
The following explains each element in detail.
In This Section
Updating Permissions for Integration Users
Printing and Exporting Integration Users
Access Control for Integration Users
Last Published Tuesday, April 15, 2025
