User Administration
The User Administration grouping node contains the following functional nodes:
- Partner Companies: An Owner Company (also referred to as a Sponsor Company) might work with one or more Partner Companies (for example, subcontractors, vendors, and so on) to work on projects/shells or company-level activities. Use this functional node to grant Partner Company users access to specific company-level and project/shell-level features.
- Company Users: Company users are the main users that will have access to the system and your company's functions. Use this functional node to grant Company users access to specific company-level and project/shell-level features.
- Partner Users: Partner users are members of Partner Companies that can be given permission to access the system and specific company functions. Use this functional node to grant Partner users access to specific company-level and project/shell-level features.
- Groups: Use this functional node to create and manage Company-level groups, such as Company Administrators. You can also specify the applicable Permissions for the group and manage the group membership.
- Task Reassignment: Use this functional node to access comprehensive lists of active tasks currently assigned to active and inactive users. Using the Task Reassignment - Active User Tasks and Task Reassignment - Inactive User Tasks logs, you can reassign individual tasks to other active users.
- Integration Users: Integration users can perform integration, using external programs to import data into the system. Use this functional node to grant Integration users access to run requests related to Representational State Transfer (REST)ful services, such as Workflow Business Process Permissions.
- Access Control: Use this option to see which see which users and groups have access to each module, ranging from Administration (Admin) mode to access for the individual Managers, and at what permission setting, and to make changes.
See Also
Company Workspace Landing Page (Admin)
Configuration Package Management
Last Published Tuesday, April 15, 2025
