Company Information
The Company Information grouping node displays information about your organization. If you have the applicable permissions, you can update some fields on this page. For more information, see Updating Company Information.
- Status: (Read-only) If you are signed in as a Site Administrator, a label, such as Active or Inactive appears next to the Company Information label.
- Activate/Deactivate Account: If you are signed in as a Site Administrator, an option to activate or deactivate the company appears in the upper-right corner.
- Audit Log: Displays a record of changes made, the date the change was processed, and the name of the user that made the change. Lets you search through and print the log.
- Company Photo: Displays a picture for the company, such as the company logo.
- About
- Name: Displays the name of your company.
- Short Name: Displays the short name of your company.
- Contact: Displays the first and last name of the person to contact within your company, such as the name of the Company Administrator.
- DUNS: Displays the Data Universal Numbering System (DUNS) number assigned to your company.
- Home URL: Displays the main Uniform Resource Locator (URL) for your company.
- Help URL: Displays an additional URL to point to internal documentation regarding company policies or practices, an intranet site, or other internal information.
- Authentication Key: (Read-only) If you are signed in as a Site Administrator and a key was provided when the company environment was configured, displays an encoded entry.
- Base Currency: Displays the default currency used by the company. Although it might be set by Oracle when the system is first provisioned, the Base Currency must be selected the first time that the Company Administrator signs in. No other users are allowed to sign in until the Company Administrator sets the Base Currency. Because the type of currency plays a large role in nearly all financial functions, the Base Currency cannot be changed after data has been entered into the system. For more information, see Base Currency Confirmation.
Note: Whatever is specified for your Base Currency, for example, EUR for Euro, is used as the default setting for this field and remains unchanged whenever a Configuration Package is processed.
- Description: Displays information that describes your company, such as its line of business.
- Addresses: At a minimum, displays the default company address.
See Also
Company Workspace Landing Page (Admin)
Configuration Package Management
Last Published Tuesday, April 15, 2025
