Standards & Libraries
The Standards & Libraries grouping node contains the following functional nodes:
- Calendars: Lets you create multiple calendars, which supports using a library of calendars that can be selected for use at the company, shell, and project levels and accounts for holidays and other non-working days in a range of locales.
- Cash Flow
- Data Sources: Lets you define sources and curve types, and customize the display and order for graphical elements.
- Distribution Profiles: Lets you create and manage percentage-distribution profiles that can be used for the display of cash-flow graphics.
- Templates: Lets you create and manage cash-flow templates that can be selected in projects/shells.
- Currencies: Use this node to create and manage different currencies to suit business requirements.
- Exchange Rates: Use this node to create and manage exchange rates and the effective dates of those rates for different currencies.
- Permission Templates: Lets you create templates for permission sets that you can subsequently apply to individual users or groups.
- User Preference Templates: Lets you create templates for a default set of user preferences that you can subsequently apply to existing users and to new users. New users will be created with the preferences defined by the active template.
- Approved Email List: In addition to the dedicated company email address that was originally specified for your company, use this node to create and manage project/shell-specific identifiers that are used in conjunction with the company email. You can also specify additional email addresses that are approved for use within your organization.
- Period Structure: Use this node to define periods used for project/shell cash flows, shell properties, and portfolio management.
- Seasonal Dates: Supports work-order management for preventive maintenance. This node is read-only and not available for Unifier Essentials.
See Also
Company Workspace Landing Page (Admin)
Configuration Package Management
Last Published Tuesday, April 15, 2025
