Initial Oracle Integration Setup
To configure Oracle Integration for Unifier Essentials, complete the initial setup outlined below.
Prerequisites
Ensure the following:
Initial Setup Procedure
To establish a connection with Oracle Integration:
  1. Go to the Company Workspace tab and switch to Admin mode.
  2. In the left Navigator, select Integrations, and select Oracle Integration Cloud.
  3. In the right pane, select the Connect tab.
  4. Set up the connection with Oracle Integration:
    1. (Initial setup) Enter the following information the first time you connect with Oracle Integration:
      • OIC URL: Enter a valid Oracle Integration URL to send and receive data between Unifier Essentials and Oracle Integration. This might be an instance embedded with Unifier Essentials or you might have your own instance of Oracle Integration.
      • IDCS URL: Enter a valid Oracle Identity Cloud Service (IDCS) URL hosting Oracle Integration.
      • Client ID: Enter the client ID generated for adding Unifier Essentials as a trusted application in Oracle Integration.
      • Client Secret: Enter the client secret generated for adding Unifier Essentials as a trusted application in Oracle Integration.
      • App Scope: Enter the App Scope generated for adding Oracle Integration as a trusted application in Oracle Integration. It generally ends with 'urn:opc:resource:consumer::all'.
    2. Click Save & Generate Access Token.
      This generates a token and sets the Enable Integration fields to Yes on connecting successfully. Otherwise, recheck your Oracle Integration configuration details.
      Note: For subsequent use, integration users can set the Enable Integration? field to connect with Oracle Integration as-needed, on demand.
  5. Select the Unifier Essentials modules that will use integrations from Oracle Integration:
    1. In the Integrations tab, click Manage Modules and select/deselect any of the following modules:
      • Business Processes
      • System Activity Sheets
      • Manual Activity Sheets
      • Master Rate Sheet
    2. Click Save.
  6. For each module selected in the previous step, add one or more endpoints as follows:
    1. In the left pane of the Integrations tab, select a module. For example, select Business Processes.
    2. In the right pane, click Add Integration.
    3. For each endpoint, enter the following information:
      • Integration Name: (Required) Enter a user-friendly name for the integration being set up.
      • OIC Name: Enter the name of the integration created in Oracle Integration.
      • API Path: (Required) Copy the relative path of the endpoint URL from the POST field on the Configure and Run page of the integration from Oracle Integration. It usually starts with /ic/api/.
    4. In the Action field, click Submit. The Usage status of the integration defaults to Unused.
      Note: If the integration is being used in the BP Setup/Activity Setup, the Usage status is set as In Use.
    5. In the Activate field, slide right to activate the integration.
      When the integration is triggered as part of a BP workflow event or Get Data of System Activity Sheet, the job status can be viewed from the following locations:
      • OIC Integration Log under the System Information node
      • Integration Log of the BP record/Activity Sheet History tab
      However, the progress of the integration execution is available in the OIC Integration Log only if the integration has a call to invoke the Unifier Essentials API with a status and corresponding error message. For more details, see the topic, Callback API to Update Oracle Integration Recipe Instance in the Unifier Essentials Integration Interface Guide.
      Tip: To temporarily disable a specific integration, slide left in the Activate field. To permanently delete a specific integration, see Deleting an Oracle Integration Connection.
  7. Add users or groups with appropriate permissions to access and use integrations from Oracle Integration:
    1. In the left Navigator, select User Administration, and then select Access Control.
    2. In the right pane, expand Administration Mode Access, expand Integrations, and then select Oracle Integration Cloud.
    3. In the Module Permission Settings window, click Add.
      1. In the Select Users/Groups pane, click Add Users/Groups to add users or groups, and click OK.
      2. In the Permission Settings pane, assign any of the following permissions to users or groups:
        Configure: Select this option to allow users or groups to configure the Oracle Integration connection.
        View: Select this option to allow users or groups to only view the Oracle Integration connection.
      3. Click OK.
    4. Click Apply.
Proceed with Setting Up Business Processes With Oracle Integration as outlined in the Primavera Unifier Modules Setup Administration Guide.
See Also
Enabling Oracle Integration Connection
Disabling Oracle Integration Connection
Last Published Tuesday, April 15, 2025
