Disabling Oracle Integration Connection
To disable the Oracle Integration connection:
- Go to the Company Workspace tab and switch to Admin mode.
- In the left Navigator, select Integrations, and select Oracle Integration Cloud.
- In the Connect tab, set Enable Integration to No.
Tip: To disable a specific integration, deactivate that integration.
See Also
Unifier Essentials and Oracle Integration
Initial Oracle Integration Setup
Enabling Oracle Integration Connection
Last Published Tuesday, April 15, 2025
