Enabling Oracle Integration Connection
After initial setup, you can connect with Oracle Integration as-needed, on demand.
To enable the Oracle Integration connection:
  1. Go to the Company Workspace tab and switch to Admin mode.
  2. In the left Navigator, select Integrations, and then select Oracle Integration Cloud.
  3. In the Integrations tab, specify or recheck the endpoints from Oracle Integration.
  4. In the Connect tab:
    1. Enter or recheck the connection parameters.
    2. Click Save & Generate Access Token.
      This generates a token and sets the Enable Integration field to Yes on connecting successfully. Otherwise, recheck your Oracle Integration configuration details.
  5. Proceed to work on your business processes (BPs).
See Also
Unifier Essentials and Oracle Integration
Initial Oracle Integration Setup
Disabling Oracle Integration Connection
Last Published Tuesday, April 15, 2025
