Creating and Managing User Preference Templates
You can use User Preference templates to configure the default user preference settings for new users. You can also use templates to update existing users' user preferences by "pushing" the preference options. In this way, you can establish a standard for your users' preference settings.
Note: If your Oracle Cloud Administrator used Primavera Administration to create users, you can use a user preference template within Unifier Essentials to update user account information such as the time zone and a date format.
In This Section
Create a User Preferences Template
Update Users with User Preferences Template
Last Published Tuesday, April 15, 2025
