Keyboard Shortcuts
You can use your keyboard to navigate throughout the CIC Analytics Administration application, and access frequently used or important functionality. Use the Tab key to cycle through elements within the application, and press Enter or Space bar to access them. Some keyboard shortcuts may change depending on the browser you use.
Common Shortcuts
The following shortcuts are common to all pages of CIC Analytics Administration application:
Related Topics
Getting Started
Construction Intelligence Cloud Analytics Administration Application Overview
Accessing CIC Analytics Administration Application
About Your Login Credentials
Reset Your Password
Product Accessibility
Navigating the CIC Analytics Administration Application
CIC Analytics Application Setup Roadmap
Last Published Friday, March 7, 2025
