Configuring Log Settings
You can use the log settings to set how the system logs errors and warnings.
To set your log settings:
  1. Open the Primavera P6 Administrator.
  2. In the Configurations drop-down list, select your configuration.
  3. In the sidebar select Log.
  4. Select Asynchronous to log messages after the previous one has been logged for better performance. The default is unselected.
  5. To configure Console Logger settings:
    1. Select Enabled, to enable the console logger. The default is unselected.
    2. In the Severity Level drop-down menu, select one of the following severity levels for the Console Logger:
      • debug
      • info
      • warn
      • error
        Notes:
        • The default severity level is info.
        • The ranges are inclusive. For example, select "debug" to log all messages; select "warning" to log both warning and error level messages.
  6. To configure File Logger settings:
    1. Select Enabled, to enable the file logger. The default is selected.
    2. Select HTML, to log as HTML, or leave the option clear to log as plain text.
    3. Note: Log files are created in a folder named WebAccessLogs, located in webaccesshome\WebAccessLogs
    4. In the Archive Size field, enter the minimum size (in Kb) a log file must be before it is archived.
      The default value is 1024.
      Enter a value between 1024 and 15360.
    5. In the Severity Level drop-down menu, select one of the following severity levels for the File Logger:
      • debug
      • info
      • warn
      • error
        Notes:
        • The default severity level is error.
    6. In the Number of Archive Files field, enter the maximum number of log files to use.
      Enter a value between 2 and 2073600000. The default value is 6.
      Note: The default files are named WebAccessLog0.html through WebAccessLog5.html.
  7. To configure Email Logger settings:
    Note: The email logger only sends information about Error messages.
    1. Select Enabled, to enable the Email Logger. The default is unselected.
    2. In the SMTP Host field, enter SMTP server that will send the email message.
    3. In the From Email Address field, enter the email address that you want to send log messages.
    4. In the To Email Address field, enter the email address where you would like log messages sent.
    5. In the Email Subject field, enter the subject line for error emails. The default value is P6 Web Access error.
Related Topics
About the Configurations Tab in the Primavera P6 Administrator
Configuring Localization Settings
Configuring Session Management Settings
Configuring Database Instance Settings for On-Premises
Configuring Thread Pool Settings
Configuring AutoVue without VueLink
Configuring Outside In
Configuring Client Properties Settings
Configuring Web Proxy Settings
About Application Settings in the Primavera P6 Administrator
About the Primavera P6 Administrator Services Settings
Configuring P6ProCloudConnect Settings
Configuring GeoCodeProvider Settings
Configuring Integration API Server Settings
About Configuring P6 EPPM Web Services in the Primavera P6 Administrator
Configuring P6 Team Member Settings
Configuring Diagnostics Settings
Copyright © 1999, 2023
Last Published Tuesday, October 31, 2023
