- Open the Primavera P6 Administrator.
- In the Configurations drop-down list, select your configuration.
- In the sidebar select Team Member if you want to alter the following default values:
Note: Changes to these settings require you to restart the P6 Team Member server.
- Initial connection pool size: 10
- Maximum active database connections: 150
- Maximum idle database connections: -1
- Minimum idle database connections: 10
- Enabled: Selected
- Severity Level: Error
Note: Other Severity Level options include the following:
- off
- fatal
- warn
- info
- debug
- trace
- all
- Log File Name:
p6tmweb.log
