Configuring Outside In
Outside In converts documents uploaded to your content repository into a raster-image file.
To configure Outside In:
  1. In the Primavera P6 Administrator, do the following:
    1. Select your configuration.
    2. In the sidebar, select Document Viewing.
    3. In the Fonts Directory field, enter the full path to your operating system-specific fonts folder. For example, C:\Windows\Fonts.
      Note: You cannot convert documents in languages that do not have a compatible font installed in the Fonts Directory. Before you convert these documents you must install the appropriate language font.
    4. In the Images Directory field, enter the full path to your Outside In images folder. For example, P6EPPM_HOME\P6\outsidein\ImageExport\Images.
  2. Navigate to P6EPPM_HOME\P6.
  3. Run outsideInConfig.cmd or outsideInConfig.sh (based on your operating system).
Related Topics
About the Configurations Tab in the Primavera P6 Administrator
Configuring Localization Settings
Configuring Session Management Settings
Configuring Database Instance Settings for On-Premises
Configuring Thread Pool Settings
Configuring AutoVue without VueLink
Configuring Log Settings
Configuring Client Properties Settings
Configuring Web Proxy Settings
About Application Settings in the Primavera P6 Administrator
About the Primavera P6 Administrator Services Settings
Configuring P6ProCloudConnect Settings
Configuring GeoCodeProvider Settings
Configuring Integration API Server Settings
About Configuring P6 EPPM Web Services in the Primavera P6 Administrator
Configuring P6 Team Member Settings
Configuring Diagnostics Settings
Copyright © 1999, 2023
Last Published Tuesday, October 31, 2023
