Use the Project Issues window to add, edit, and delete issues for the open project and to send Email notifications about issues. You can customize the columns that display in the issue table, and you can group, sort, and filter issues.
To display the Project Issues window, do one of the following:
- Click  on the Project toolbar. on the Project toolbar.
- On the Project menu, choose Issues.
When working in the Project Issues window, you can:
- Use the Edit menu on the Menu bar or the Edit toolbar to add, delete, cut, copy, and paste issues.
- Use the Display Options bar, the View menu on the Menu bar, or the Layout toolbar to customize the issue table.
- On the Edit toolbar, click  to display and add comments about the selected issue's history, and click to display and add comments about the selected issue's history, and click to select who you want to notify about the selected issue and send an Email. to select who you want to notify about the selected issue and send an Email.
- Use Project Issue Details or the issue table to define general and detailed information for each issue. To show or hide Issue Details, click  on the Bottom Layout toolbar. on the Bottom Layout toolbar.
Tip
- Use the Issue Navigator dialog box to track the open project's issues. This includes associated activities, resources, and work breakdown structure (WBS) elements.
Notes
- After opening the Project Issues window, the window remains open until you close all open projects or you close the window; if you open or navigate to another window without closing the Project Issues window, click the Project Issues tab to return to the window at any time.
- If resource security is enabled, you can only view resources you have access to (under the resource root node) and current project resources.
Related Concepts
- Issues
Related Tasks
You can perform all of the following tasks in the Project Issues window:
- Add an issue
- Assign a tracking layout to an issue
- Assign an issue to a resource
- Assign an issue to an activity
- Change an issue's status
- Delete an issue
- Send Email about an issue
- Track the duration of an issue
- View or add to an issue's history
