Sample of Joining Primavera Data Warehouse Data and MVDEMO Data
The following provides an example of joining location data from the Primavera Data Warehouse database to the sample MVDEMO data:
- Log into OBI with an account that has a BI Administrators role.
- Select Administration.
- Under Map Data Management, click Manage Map Data.
- In the Manage Map Data page:
- Select the Layers tab.
- Select Import Layers.
- In the Import Layers dialog box:
- In the Look in field, select mvdemo.
- Select COUNTRIES_ALL_LABEL_CLEAR and US_STATES_BI.
- Click OK.
- Select COUNTRIES_ALL_LABEL_CLEAR and click the Edit layers icon.
Related Topics
Installing and Configuring MVDEMO Sample Spatial Data
Importing Modified MVDEMO Themes
Configuring mapViewerConfig.xml for MVDEMO
Verifying the MapViewer Connection
Adding the ELOCATION_MAP for MVDEMO
Configuring Background Maps for MVDEMO
Last Published Wednesday, July 3, 2024
