Configuring Client Properties Settings
Primavera P6 Administrator Setup Tasks > About the Configurations Tab in the Primavera P6 Administrator
You can use the log settings to set how the system logs errors and warnings.
To set your log settings:
- Open the Primavera P6 Administrator.
- In the Configurations drop-down list, select your configuration.
- In the sidebar selectClient Properties.
- Select Compress HTML Content to compress responses from REST API and Web Services.
- In the HTTP Server And Port Override field, enter the HTTP front-end web server and port that P6 clients should use. Use URL format: http[s]://servername[:port], do not include context root.
Note This setting is only necessary if problems are encountered while using a front-end web server proxy.
- In the Ajax Request Wait Timeout field, specify how long the server should wait for Business Process Management workflows and Action Required tabs to respond.
Related Topics
Configuring Localization Settings
Configuring Session Management Settings
Configuring Database Instance Settings for On-Premises
Configuring Thread Pool Settings
Configuring AutoVue without VueLink
Configuring Web Proxy Settings
About Application Settings in the Primavera P6 Administrator
About the Primavera P6 Administrator Services Settings
Configuring P6ProCloudConnect Settings
Configuring GeoCodeProvider Settings
Configuring Integration API Server Settings
About Configuring P6 EPPM Web Services in the Primavera P6 Administrator
Configuring P6 Team Member Settings
Configuring Diagnostics Settings
Last Published Friday, March 27, 2026
