Configuring Localization Settings
Primavera P6 Administrator Setup Tasks > About the Configurations Tab in the Primavera P6 Administrator
Your localization settings specify the language you see when you log in to P6 and the country for server string constants. The Java application uses this setting to ensure all instances of P6 EPPM will use the same localization settings.
Note
- The localization used by your operating system will have priority for the language used. The localization setting in P6 ensures P6 EPPM uses your preferred language if the JVM fails to recognize your operating system's localization settings.
- If you change the localization of P6 on the login page, you will only change the language for your P6 user interface. It does not translate your data or change the convention followed by your region.
- Changes to these settings require you to restart the P6 server.
To set your language and country:
- Open the Primavera P6 Administrator.
- In the Configurations drop-down list, select your configuration.
- In the sidebar select Localization.
- In the System Language drop-down list, select your language. The default value is English (en).
- In the System Country drop-down list, select your country. The default value is US.
Tip Go to http://download.oracle.com/javase/1.5.0/docs/guide/intl/locale.doc.html or the Tested Configurations document for a list of supported languages and countries.
Related Topics
Configuring Session Management Settings
Configuring Database Instance Settings for On-Premises
Configuring Thread Pool Settings
Configuring AutoVue without VueLink
Configuring Client Properties Settings
Configuring Web Proxy Settings
About Application Settings in the Primavera P6 Administrator
About the Primavera P6 Administrator Services Settings
Configuring P6ProCloudConnect Settings
Configuring GeoCodeProvider Settings
Configuring Integration API Server Settings
About Configuring P6 EPPM Web Services in the Primavera P6 Administrator
Configuring P6 Team Member Settings
Configuring Diagnostics Settings
Last Published Friday, March 27, 2026
