Project Thresholds window
Use the Project Thresholds window to create, view, edit, and monitor thresholds for the open project. You can monitor a threshold at the work breakdown structure (WBS) level or the activity level to identify issues. You can customize the columns that display in the threshold table, and you can group, sort, and filter thresholds.
To display the Project Thresholds window, do one of the following:
When working in the Project Thresholds window, you can:
Tip
Related Concepts
Related Tasks
You can perform all of the following tasks in the Project Thresholds window:
Related Topics
Layout Toolbar
Edit Toolbar
Menu bar
Project Toolbar
Project Threshold Details
Bottom Layout Toolbar
Monitor a threshold
Disable or enable a threshold
Delete a threshold issue
Delete a threshold
Assign a tracking layout to a threshold
Add a threshold
Threshold parameter definitions
Thresholds
View threshold issue details
Last Published Friday, December 12, 2025
