Transferring the Additive Schema, PRET, and Data Migration Files to the z/OS Host
Use the following procedure to transfer the schema DDL files and the PRET and data migration files generated by the Upgrade Wizard on the midtier up to Pause #1 to the z/OS host.
Note: Before transferring the generated files to the z/OS host, edit
them as required by relevant publications such as bulletins, alerts,
and Siebel CRM Update Guide and Release Notes on My Oracle Support.
To transfer the files generated on the midtier
Navigate to the
\DB2390\dbsrvr\dboutput\upgrade
directory (Windows) or the /DB2390/dbsrvr/dboutput/upgrade
directory (UNIX) and double-click the ftp_pause1.bat file (Windows) or issue the following command (UNIX):ftp -vn < ftp_pause1.txt > ftp_pause1.log
Enter your TSO password and press Enter.
All the Pause #1 files are transferred from the midtier to the z/OS host.
Review the ftp_pause1.log file which is created in the upgrade directory and verify that all the files listed in the ftp_pause1.txt file transferred successfully to z/OS staging data sets.
Note: If the FTP script fails because the password prompt is
suppressed, then add the password after the user name in the ftp_pause1.txt,
ftp_stg1.txt, ftp_pause1.txt, ftp_pause2.txt, and ftp_pause3.txt files
and repeat the this procedure.
