Preparing the Additive Schema and JCL Files on the z/OS Host
Upgrades: All upgrades.
Environments: All environments
This topic is part of an upgrade process. See Performing a Siebel Database Upgrade.
When you restart the Upgrade Wizard after creating the staging database, it generates SQL and JCL templates for the file generation process. Specifically, the following files are generated:
Additive upgrade files
Pret files
Data migration files
When the Upgrade Wizard stops at Pause # 1, you must transfer these files to data sets on the z/OS host. These data sets are then used to create the SQL and JCL templates used to perform the upgrade. These tasks are described in this topic.
Perform the following procedures:
