Attach Method for an Application |
Allows an external application to reconnect
to an existing Siebel session. |
Dim application as SiebelDataControl
Dim status as Boolean
status
= application.Attach(sessionID As String)
CurrencyCode Method for an Application |
Returns the currency code that is associated
with the division of the user position. |
Dim sCur as String
sCur = Application.CurrencyCode
Detach Method for an Application |
Returns a string that contains the Siebel
session ID. |
Dim sessionId as String
sessionId
= application.Detach()
EnableExceptions Method for an Application |
Enables or disables native Component Object
Model (COM) error handling. |
Dim bEnable as Boolean
bEnable
= trueapplication.EnableExceptions(bEnable)
GetBusObject Method for an Application |
Creates a new instance of a business object. |
Dim busObject as SiebelBusObject
set busObject = application.GetBusObject(busobjName as String)
GetLastErrCode Method for an Application |
Returns the error code for the error that Siebel CRM logged most recently. |
Dim iErr as Integer
iErr =
application.GetLastErrCode
GetLastErrText Method for an Application |
Returns the text message for the error that Siebel CRM logged most recently. |
Dim sText as String
sText =
application.GetLastErrText
GetProfileAttr Method for an Application |
Returns the name of an attribute in a user
profile. |
Dim sText as String
sText =
application.GetProfileAttr(profileAttributeName as string)
GetService Method for an Application |
Locates a business service. If this business
service is not already running, then Siebel CRM starts it. |
Dim service as SiebelService
set service = application.GetService(serviceName as String)
GetSharedGlobal Method for an Application |
Returns the shared global variables. |
Dim sText as string
sText =
application.GetSharedGlobal(globalVariableName as string)
InvokeMethod Method for an Application |
Calls a method. |
Dim sReturn as String
sReturn
= application.InvokeMethod(methodName as String, methArg1, methArg2, methArgN as String or StringArray)
Login Method for an Application |
Allows an external application to log in
to the COM Data Server, COM Data Control, or Siebel Java Data Bean,
and to access Siebel objects. |
Dim sErr as String
sErr = application.Login(connectString as String, userName as
String, password as String)
LoginId Method for an Application |
Returns the login ID of the user who started
the Siebel application. |
Dim sID as String
sID = application.LoginId
LoginName Method for an Application |
Returns the login name of the user who started
Dim sUser as String
sUser =
application.LoginName
Logoff Method for an Application |
Disconnects the Siebel client from the Siebel
Server. |
Dim SiebApp as SiebelDataControl
Dim boolVal as Boolean
boolVal
= siebApp.LogOff
NewPropertySet Method for an Application |
Creates a new property set. |
Dim PropSet as SiebelPropertySet
PropSet = oApplication.NewPropertySet
PositionId Method for an Application |
Returns the position ID of the user position. |
Dim sRow as String
sRow = application.PositionId
PositionName Method for an Application |
Returns the name of the current user position. |
Dim sPosition as String
sPosition
= application.PositionName
SetPositionId Method for an Application |
Sets the active position to a Position ID. |
status
= application.SetPositionId(sPosId)
SetPositionName Method for an Application |
Sets the active position to a position name. |
status
= application.SetPositionName(sPosName)
SetProfileAttr Method for an Application |
Personalization uses this method to set a
value for an attribute in a user profile. |
application.SetProfileAttr(name as String, value as String)
SetSharedGlobal Method for an Application |
Sets a shared global variable. |
boolVal
= SiebApp.SetSharedGlobal(varName As String, value As String)
Trace Method for an Application |
Appends a message to the trace file. |
boolVal
= siebApp.TraceOn(msg As String)
TraceOff Method for an Application |
Turns off tracing. |
boolVal=siebApp.TraceOff
TraceOn Method for an Application |
Turns on tracing. |
boolVal
= siebApp.TraceOn(fileName As String, category As String, src As String)
