Strings Quick Reference
The following table lists methods to manipulate strings.
Statement Purpose Reference
Chr
Converts a character code to a string.
Get ANSI String Method
Format
Returns an expression in a format that you specify.
Set String Format Method
InStr
Returns the position of one string in another string.
Get Substring Position Method
LCase
Converts a string to lower case.
Convert String to Lowercase Method
Left
Returns a string copied from the beginning of another string.
Get Left String Method
Len
Returns the length of a string or size of a variable.
Get String Length Method
Like
Compares the contents of two strings.
Compare Strings Operator
Lset
Copies one string to another string or assigns a custom variable to another variable.
Copy String Method
LTrim
Removes leading spaces from a string.
Remove Spaces From String Method
Mid
Returns a portion of a string.
Get Substring Method
Mid = string
Replaces part or all of one string with another string.
Replace String Method
Option Compare
Specifies the default method for string comparisons to case-sensitive or not case-sensitive.
Set String Comparison Method
Right
Returns the right portion of a string.
Get Right String Method
Rset
Right-justifies one string in another string.
Right-Justify String Method
RTrim
Removes trailing spaces from a string.
Trim Trailing Spaces From String Method
Space
Returns a string of spaces.
Get a String of Spaces Method
Str
Returns the string representation of a number.
Convert Number to String Method
StrComp
Compares two strings.
Compare Strings Method
String
Returns a string that consists of a repeated character.
Get Repeated Character String Method
Trim
Removes leading and trailing spaces from a string.
Trim Spaces From String Method
UCase
Converts a string to upper case.
Convert String to Uppercase Method
Val
Returns the numeric value of the first number that it finds in a string.
Get First Number From String Method
