Using Numeric Paging
Numeric paging is inherently not reliable because of insufficient computer protocols that exist to send a numeric page. If Siebel must send a numeric page, then you can use the Pager Pin field in the employee table to control the delay that occurs between dialing the paging phone number and sending the numeric message. You can add commas to the Pager Pin field. Two commas is equal to approximately a one second delay. It is recommended that you avoid using numeric paging in a Siebel application that is mission critical.
