Example of Creating Product Offers with Parent Actions
This topic gives one example of using parent actions in product offers. You might use this feature differently, depending on your business model.
The Parent Action field is in the Action record. For more information, see Creating Actions for Responses to Product Offers.
You use the Parent Action field when you create products offers with named parameters. For more information, see Creating Product Offers with Named Parameters.
You can also use the Parent Action field for other purposes. This example describes one possible use of parent actions for other purposes.
You have a product offer that gives 50% discount on an accessory, a product named Bluetooth Headset. The first action adds this product, and the second action gives a 50% discount to the product added in the first action. The second action has the first action as its parent action, because it uses a value from the first action.
To create this product offer with a parent action, create the product offers in the usual way, described in Process of Creating Product Offers, and when you add the Action records, enter the values described in the following procedure.
To create actions for a response to a product offer
  1. Navigate to the Administration - Product screen, then Product Offers view.
  2. Select the Product Offer that you want.
  3. Click the Responses view tab.
  4. Select the response that you want.
  5. To add the headset to the order, add a record to the Responses - Actions list, and complete the necessary fields with the values shown in the following table.
    Field Value
    Sequence
    1
    Action Name
    Add Headset
    Action Type
    New
    Action Code
    Add
    Base Product
    Bluetooth Headset
  6. To give a 50% discount for the product that was added in the first action, add a second record to the Responses - Actions list, and complete the necessary fields with the values shown in the following table.
    Field Value
    Sequence
    2
    Action Name
    Give 50% Discount
    Action Type
    New
    Action Code
    Update
    Base Product
    no value
    Field Name
    Discount Percent
    Field Value
    50
    Parent Action
    Add Headset
