Guidelines for Setting the Monitoring Level
The monitoring level determines how frequently Siebel CRM saves data to the disk. The runtime environment for Siebel Workflow sets this frequency according to the type of Workflow Process and the monitoring level you choose. Monitoring can cause a performance overhead. It is recommended that you set the monitoring level to one of the following values:
  • 0 (None) or 1 (Status) for a Workflow Process that Siebel CRM runs in a production environment.
  • 2 (Progress) or higher only to debug a Workflow Process. If you set the monitoring level to 4 (Debug), then Siebel CRM saves the Workflow Process state to the database after every Workflow Process step.
