Running a Workflow Policy with Workflow Monitor Agent
The Workflow Monitor Agent (WorkMon) is a server component that determines if the Workflow Policy conditions are met and runs actions. To run Workflow Policies, you must start the Workflow Monitor Agent. You can start and stop the Workflow Monitor Agent server task in the Administration - Server views.
This topic describes how to run a Workflow Policy using the Workflow Monitor Agent. It includes the following topics:
