Before installing ASR, ensure that the following conditions are met:
Ensure that you have access to My Oracle Support (http://support.oracle.com) and confirm your contact information is correct and current.
Make sure that all of your Exalytics machine assets have a contact assigned and that the contact is correct and current.
Identify and designate a system, outside of Exalytics, to serve as ASR Manager.
Retrieve the IP address of your ASR Manager.
Identify and verify ASR assets.
Ensure connectivity to the Internet using HTTPS.
Download and install the Oracle Exalytics Configuration Utility patch and ASR utility, on the Exalytics host machine.
Starting with Oracle Exalytics Release 1 Patchset 3 (1.0.0.3), the Oracle Exalytics Configuration Utility patch and the ASR utility are included in the base image.
Steps 1 through 4 are not applicable for users using Oracle Exalytics Release 1 Patchset 3 (1.0.0.3) or higher version.
If you are using Oracle Exalytics Release 1 Patchset 3 (1.0.0.3) or higher version, you must start at step 5.
To download and install the Oracle Exalytics Configuration utility patch and ASR utility, perform the following actions:
Download and install the Oracle Exalytics Configuration Utility patch (1.0.0.4) and ASR utility for Oracle Exalytics Release 1, Patchset 1 (ex_x2-4_config_utils_linux_x86_64.zip file) from the Oracle Software Delivery Cloud Web site at the following link:
Unzip the file into a temporary directory.
The zip file contains the files that are listed in Table 9-1.
Table 9-1 Files in the Oracle Exalytics Configuration Utility Zip File
| File Name | Notes |
Oracle Exalytics network configuration script |
ASR (Auto Service Request) on Oracle Exalytics |
ASR mail script on Oracle Exalytics |
ASR on Oracle Exalytics |
Create the following directories:
mkdir -p /opt/exalytics
mkdir -p /opt/exalytics/asr
Copy the file exalytics_configure_network.sh to /opt/exalytics/bin. Copy the following files to the /opt/exalytics/asr directory:
bda_mon_hw_asr.pl
setup_asr_ilom.pl
common_subs.pm
SUN-HW-TRAP-MIB.mib
Before copying the file, ensure that you back up the existing file as exalytics_configure_network.sh_V1 first.
Execute the Oracle Exalytics network configuration script to configure the network interfaces.
#cd /opt/exalytics/bin
#./exalytics_configure_network.sh
Complete the following steps to configure ASR:
For an OL5 based Exalytics Image, the steps are:
Go to the /opt/exalytics/asr directory, and run the following commands to add executive permissions on the two Perl files:
chmod +x bda_mon_hw_asr.pl
chmod +x setup_asr_ilom.pl
Add the following line to the /etc/inittab file:
emh1:345:respawn:/opt/exalytics/asr/bda_mon_hw_asr.pl -server
At the command line, execute the init q command to initialize and start the bda_mon server.
You can also download the patch p21565893_20000_Linux-x86-64.zip patch 21565893, unzip the patch file #unzip p21565893_20000_Linux-x86-64.zip –d /tmp/, and follow the instructions in the /tmp/readme.txt file.
For an OL6 based Exalytics Image, the steps are:
Go to the /opt/exalytics/etc/init.d/ directory, and copy the bda-monitor file to /etc/init.d/ directory by running the command:
#cp /opt/exalytics/etc/init.d/bda-monitor /etc/init.d/
If the bda-monitor file is not found in the /opt/exalytics/etc/init.d/ directory, the file can be located in the patch p21565893_20000_Linux-x86-64.zip, which can then be copied to the directory.
Run the following command to add the bda-monitor file:
#chkconfig –add bda-monitor
At the command line, execute the following command to initialize and start the bda_mon server:
# /etc/init.d/bda-monitor start
Parent topic: Installing Auto Service Request (ASR) Software
