Causa
La exportación de datos de Data Management desde Planning Modules puede fallar con el siguiente error:
ERROR ----------------------- 21 04:18:34,392 DEBUG [AIF]: Fetching rule file from essbase server for data loading: AIF0061 2018-05-21 04:18:34,401 INFO [AIF]: Starting executeDataRuleFile... 2018-05-21 04:18:34,402 DEBUG [AIF]: Locked rule file: AIF0061 2018-05-21 04:18:34,410 INFO [AIF]: Loading data into cube using data file... 2018-05-21 04:18:35,655 INFO [AIF]: Load data encountered the following errors: | Error: 3335 | 100 | "100","110","Working","BaseData","P_000","Actual","FY18","Jan",1111 |Este problema se produce en las siguientes situaciones:
Solución
