将应用程序角色分配从一个环境复制到另一个环境
使用本节中的脚本可以将应用程序角色分配从一个环境克隆到另一个环境。运行这些脚本的用户必须在这两个环境中都具有服务管理员角色。
注:
如果使用的是本文档的 PDF 版本:为避免出现换行和页脚信息从而导致这些脚本不可用,请从本主题的 HTML 版本复制脚本。
Windows
  1. 通过复制以下脚本来创建 replicatepredefinedroles.ps1。
    # Replicate application roles script
    $inputproperties = ConvertFrom-StringData(Get-Content ./input.properties -raw)
    $epmusersource="$($inputproperties.epmusersource)"
    $epmpwdsource="$($inputproperties.epmpwdsource)"
    $epmurlsource="$($inputproperties.epmurlsource)"
    $epmidentitydomainsource="$($inputproperties.epmidentitydomainsource)"
    $epmusertarget="$($inputproperties.epmusertarget)"
    $epmpwdtarget="$($inputproperties.epmpwdtarget)"
    $epmurltarget="$($inputproperties.epmurltarget)"
    $epmidentitydomaintarget="$($inputproperties.epmidentitydomaintarget)"
    $proxyserverusername="$($inputproperties.proxyserverusername)"
    $proxyserverpassword="$($inputproperties.proxyserverpassword)"
    $proxyserverdomain="$($inputproperties.proxyserverdomain)"
    $emailtoaddress="$($inputproperties.emailtoaddress)"
    $roleassignmentreport="roleassignmentreport.csv"
    function replicateroles
        # epmautomate login Source App as an IDM Admin
        echo "Logging into source application at ${epmurlsource}"
        epmautomate login ${epmusersource} ${epmpwdsource} ${epmurlsource} ${epmidentitydomainsource} ${proxyserverusername} ${proxyserverpassword} ${proxyserverdomain}
        echo "Creating role assignment report: ${roleassignmentreport}"
        epmautomate roleAssignmentReport ${roleassignmentreport}
        if (${emailtoaddress} -match "@") {
            epmautomate.bat sendMail $emailtoaddress "Role assignment report" Body="Role assignment report is attached." Attachments=$roleassignmentreport
        echo "Downloading role assignment report"
        epmautomate downloadfile ${roleassignmentreport}
        epmautomate deletefile ${roleassignmentreport}
        epmautomate logout
        echo "Creating files to use with epmautomate assignRoles"
        Get-Content ${roleassignmentreport} | ForEach-Object {
            $user=$_.split(',')[0]
            $rolename=$_.split(',')[4]
            if ($rolename -like '*User' -And $rolename -notlike '*Power User') {
                $rolenamearray=$rolename.split(" ")
                $arraysize=$rolenamearray.count
                $rolename="User"
                if ($arraysize.count -le 2) {
                    echo "${user}" | Out-File -Append -Encoding "UTF8" "role-${rolename}.csv"
            elseif ($rolename -like '*Viewer') {
                $rolename="Viewer"
                if ($arraysize -le 2) {
            elseif ($rolename -like '*Power User') {
                $rolename="Power User"
                if ($arraysize -le 3) {
            elseif ($rolename -like '*Service Administrator') {
                $rolename="Service Administrator"
            elseif ($rolename -like 'Planner') {
                echo "${user}" | Out-File -Append -Encoding "UTF8" "role-User.csv"
    # Add header and format
        $rolefiles = Get-ChildItem "role-*.csv"
        foreach ($rolefile in $rolefiles) {
            $rolefilecontent = Get-Content "$rolefile"
            $headerline='User Login'
            Set-Content $rolefile -value $headerline,$rolefilecontent
            $txt = [io.file]::ReadAllText("$rolefile") -replace "`r`n","`n"
            [io.file]::WriteAllText("$rolefile", $txt)
    # epmautomate login Target App as an IDM Admin
        echo "Logging into target application at ${epmurltarget}"
        epmautomate login ${epmusertarget} ${epmpwdtarget} ${epmurltarget} ${epmidentitydomaintarget} ${proxyserverusername} ${proxyserverpassword} ${proxyserverdomain}
            $rolenamecsv=$rolefile.BaseName.split('-')[1]
            $rolename=$rolenamecsv.split('.')[0]
            epmautomate deletefile "${rolefile}" | Out-Null
            echo "Uploading file ${rolefile}"
            epmautomate uploadfile "${rolefile}"
            echo "Assigning ${rolename} roles"
            epmautomate assignRole "role-${rolename}.csv" "${rolename}"
            epmautomate deletefile "role-${rolename}.csv"
        epmautomate logout
        rm deletefile*.log | Out-Null
    function init
        # delete ${role}.csv files
            $rolefileexists=Test-Path $rolefile
            if ($rolefileexists) {
                rm "${rolefile}"
    echo "Replicate application roles script started"
    init
    replicateroles
    echo "Replicate application roles script completed"
  2. 通过复制以下脚本来创建 input.properties 文件。
    epmusersource=EPM USER FOR SOURCE ENVIRONMENT
    epmpwdsource=EPM PASSWORD FILE FOR SOURCE ENVIRONMENT
    epmurlsource=EPM URL FOR SOURCE ENVIRONMENT
    epmidentitydomainsource=EPM IDENTITY DOMAIN FOR SOURCE ENVIRONMENT
    epmusertarget=EPM USER FOR TARGET ENVIRONMENT
    epmpwdtarget=EPM PASSWORD FILE FOR TARGET ENVIRONMENT
    epmurltarget=EPM URL FOR TARGET ENVIRONMENT
    epmidentitydomaintarget=EPM IDENTITY DOMAIN FOR TARGET ENVIRONMENT
    proxyserverusername=PROXY SERVER USER NAME
    proxyserverpassword=PROXY SERVER PASSWORD FILE
    proxyserverdomain=PROXY SERVER DOMAIN
    emailtoaddress=EMAIL_TO_ADDRESS
  3. 根据需要更新 input.properties。有关必须为此文件中的属性设置的值的信息,请参阅下表。
    更新 input.properties
    参数 说明
    epmusersource 在源环境中具有身份域管理员和服务管理员角色的用户的用户名。
    示例:
    Windows:set epmusersource="jDoe"
    Linux/UNIX:epmusersource="jDoe"
    epmpwdsource 用户的密码或加密密码文件的绝对路径。
    示例:
    Windows:set epmpwdsource="Example"
    Linux/UNIX:epmpwdsource="Example"
    epmurlsource 要从中复制用户的环境的 URL。
    示例:
    Windows:set epmurlsource="https://example.oraclecloud.com"
    Linux/UNIX:epmurlsource="https://example.oraclecloud.com"
    epmidentitydomainsource 源环境使用的身份域的名称。
    示例:
    Windows:set epmidentitydomainsource="example_source_dom"
    Linux/UNIX:epmidentitydomainsource="example_source_dom"
    epmusertarget 在目标环境中具有身份域管理员和服务管理员角色的用户的用户名。
    示例:
    Windows:set epmusertarget="John.Doe"
    Linux/UNIX:set epmusertarget="John.Doe"
    epmpwdtarget 用户的密码或加密密码文件的绝对路径。
    示例:
    Windows:set epmpwdtarget="Example1"
    Linux/UNIX:epmpwdtarget="Example1"
    epmurltarget 要在其中创建用户的环境的 URL。
    示例:
    Windows:set epmurltarget="https://example.oraclecloud.com"
    Linux/UNIX:epmurltarget="https://example.oraclecloud.com"
    epmidentitydomaintarget 目标环境使用的身份域的名称。
    示例:
    Windows:set epmidentitydomaintarget="example_target_dom"
    Linux/UNIX:epmidentitydomaintarget="example_target_dom"
    proxyserverusername 使用具有 Internet 访问控制权的代理服务器对安全会话进行身份验证的用户名。删除此属性的所有未使用的实例。
    示例:
    Windows:set proxyserverusername="Example"
    Linux/UNIX:proxyserverusername="Example"
    proxyserverpassword 用于在代理服务器中对用户进行身份验证的密码。删除此属性的所有未使用的实例。
    示例:
    Windows:set proxyserverpassword="examplePwd"
    Linux/UNIX:proxyserverpassword="examplePwd"
    proxyserverdomain 为代理服务器定义的域的名称。删除此属性的所有未使用的实例。
    示例:
    Windows:set proxyserverdomain="exampleDom"
    Linux/UNIX:proxyserverdomain="exampleDom"
    emailtoaddress (可选)要将角色分配报表发送到的电子邮件地址。仅当指定此值时,才会通过电子邮件发送报表。
    示例:emailtoaddress=john.doe@example.com
Linux/UNIX
  1. 通过复制以下脚本创建 input.properties 文件:
    javahome=JAVA HOME
    epmautomatescript=EPM AUTOMATE SCRIPT LOCATION
  2. 更新 input.properties。有关必须指定的值的信息,请参阅“表 3-*”。此外,必须为以下属性指定值:
    • javahome:要在其中安装 Java 的目录的绝对路径。
    • epmautomatescript:epmautomatescript.sh 的位置;例如,epmautomatescript="/home/user1/epmautomate/bin/epmautomate.sh"
  3. 通过复制以下脚本来创建 replicatepredefinedroles.sh。
    #!/bin/sh
    . ./input.properties
    export JAVA_HOME=${javahome}
    replicateroles()
        # epmautomate login Source App as an DM Admin
        ${epmautomatescript} login ${epmusersource} ${epmpwdsource} ${epmurlsource} ${epmidentitydomainsource} ${proxyserverusername} ${proxyserverpassword} ${proxyserverdomain}
        ${epmautomatescript} roleAssignmentReport ${roleassignmentreport}
        if [[ "${emailtoaddress}" == *"@"* ]]
        then
            ${epmautomatescript} sendMail $emailtoaddress "Role assignment report" Body="Role assignment report is attached." Attachments=$roleassignmentreport
        fi
        ${epmautomatescript} downloadfile ${roleassignmentreport}
        ${epmautomatescript} deletefile ${roleassignmentreport}
        ${epmautomatescript} logout
        while read line
        do
            user=$(echo "${line}" | cut -d',' -f1)
            rolename=$(echo "${line}" | cut -d',' -f5)
            if [[ "$rolename" == *"User" ]] && [[ "$rolename" != "*Power User" ]]
            then
                count=$(echo "${rolename}" | wc -w);
                rolename="User"
                if [[ $count -le 2 ]]
                then
                    echo "${user}" >> "role-${rolename}.csv"
                fi
            elif [[ "$rolename" == *"Viewer" ]]
            then
                rolename="Viewer"
                then
                fi
            elif [[ "$rolename" == *"Power User" ]]
            then
                if [[ $count -le 3 ]]
                then
                fi
            elif [[ "$rolename" == *"Service Administrator" ]]
            then
                then
                fi
            elif [[ "$rolename" == "Planner" ]]
            then
                    echo "${user}" >> "role-User.csv"
            fi
        done < ${roleassignmentreport}
        # write header line
        for f in role-*.csv
        do
            sed -i '1iUser Login' "$f"
        done
        ${epmautomatescript} login ${epmusertarget} ${epmpwdtarget} ${epmurltarget} ${epmidentitydomaintarget} ${proxyserverusername} ${proxyserverpassword} ${proxyserverdomain}
        for rolefile in role-*.csv
        do
            rolenamecsv=$(echo "$rolefile" | cut -d'-' -f2)
            rolename=$(echo "$rolenamecsv" | cut -d'.' -f1)
            ${epmautomatescript} deletefile "${rolefile}" > /dev/null 2>&1
            ${epmautomatescript} uploadfile "${rolefile}"
            echo "Assigning roles"
            ${epmautomatescript} assignrole "${rolefile}" "${rolename}"
        done
        rm deletefile*.log > /dev/null 2>&1
    init()
        # delete role-${role}.csv files
        for f in role-*.csv
        do
            rm "$f" > /dev/null 2>&1
        done
    init
    replicateroles
  4. 更新 replicatepredefineroles.sh。有关必须指定的值的信息,请参阅上表。此外,必须为以下属性指定值:
