建立角色指派和撤銷稽核報表
使用本節中的 PowerShell 指令碼以自動執行建立稽核報表的程序,此報表詳細說明環境中的角色指派與角色撤銷。
複製下列指令碼以建立 AuditReportRoleAssignment.bat。此包裝函式批次指令碼會呼叫 PowerShell 指令碼 AuditReportRoleAssignment.ps1,原始程式碼在本案例的稍後部分提供。
註:
  • 執行 AuditReportRoleAssignment.bat 的輸入參數包括 username、password_file 及 service_url。
  • 如果密碼包含特殊字元,請參閱處理特殊字元。
指令碼:AuditReportRoleAssignment.bat
@echo off
set paramRequiredMessage=Syntax: AuditReportRoleAssignment.bat USERNAME PASSWORD_FILE URL
if "%~1" == "" (
   echo User Name is missing.
   echo %paramRequiredMessage%
   exit /b 1
if "%~2" == "" (
   echo Password_File is missing.
   exit /b 1
if "%~3" == "" (
   echo URL is missing.
   exit /b 1
PowerShell.exe -File AuditReportRoleAssignment.ps1 %*
指令碼:AuditReportRoleAssignment.ps1
# EPM Automate Role Assignment Audit Report Script
$username=$args[0]
$password=$args[1]
$url=$args[2]
# Generic variables
$date=$(get-date -f dd_MM_yy_HH_mm_ss)
$datedefaultformat=$(get-date)
$logdir="./logs/"
$logfile="$logdir/epmautomate-provisionauditreport-" + $date + ".log"
$reportdir="./reports/"
$provisionreport="provreport-audittest-" + $date + ".csv"
$provisionreporttemp="./provreport-audittest-temp.csv"
$provisionreportunique="./provreport-audittest-unique.csv"
$provisionreportbaselineunique="./provreport-audittest-baseline-unique.csv"
function EchoAndLogMessage
    $message=$args[0]
    echo "$message"
    echo "$message" >> $logfile
function Init
    $logdirexists=Test-Path $logdir
    if (!($logdirexists)) {
        mkdir $logdir 2>&1 | out-null
    $logfileexists=Test-Path $logfile
    if ($logfileexists) {
        rm $logfile 2>&1 | out-null
    $reportdirexists=Test-Path $reportdir
    if (!($reportdirexists)) {
        mkdir $reportdir 2>&1 | out-null
function PostProcess
    rm $provisionreporttemp
    mv -Force $provisionreportunique $provisionreportbaselineunique
function ProcessCommand
    $op=$args
    echo "EPM Automate operation: epmautomate.bat $op" >> $logfile
    epmautomate.bat $op >> $logfile 2>&1
    if ($LASTEXITCODE -ne 0) {
        echo "EPM Automate operation failed: epmautomate.bat $op. See $logfile for details."
        exit
function RunEpmAutomateCommands
    EchoAndLogMessage "Running EPM Automate commands to generate the audit report."
    ProcessCommand login $username $password $url
    ProcessCommand provisionreport $provisionreport
    ProcessCommand downloadfile $provisionreport
    ProcessCommand deletefile $provisionreport
    ProcessCommand logout
function CreateProvisionReportTempFile
    # Loop through iteration csv file and parse
    Get-Content $provisionreport | ForEach-Object {
        $elements=$_.split(',')
        echo "$($elements[0]),$($elements[2])" >> $provisionreporttemp
function CreateUniqueElementsFile
    gc $provisionreporttemp | sort | get-unique > $provisionreportunique
function CheckBaselineAndCreateAuditReport
    $provisionreportbaselineuniqueexists=Test-Path $provisionreportbaselineunique
    if (!($provisionreportbaselineuniqueexists)) {
        EchoAndLogMessage "Could not find a baseline audit report to compare with. Audit report will be created next time you run test."
    } else {
        CreateAuditReport
function CreateAuditReport
    $auditreport=$reportdir + "auditreport-"+ $date + ".txt"
    $additions = @()
    $deletions = @()
    EchoAndLogMessage "Comparing previous audit report with the current one."
    $compare=compare-object (get-content $provisionreportunique) (get-content $provisionreportbaselineunique)
    $compare | foreach  {
        if ($_.sideindicator -eq '<=')
            $additions += $_.inputobject
        } elseif ($_.sideindicator -eq '=>') {
            $deletions += $_.inputobject
    echo "Provisioning Audit Report for $datedefaultformat" > $auditreport
    echo "------------------------------------------------" >> $auditreport
    if ($additions.count -ne 0)
        echo " "          >> $auditreport
        echo "Additions:" >> $auditreport
        foreach($element in $additions) { echo "$element" >> $auditreport }
    if ($deletions.count -ne 0)
        echo "Deletions:" >> $auditreport
        foreach($element in $deletions) { echo "$element" >> $auditreport }
    if (($additions.count -eq 0) -and ($deletions.count -eq 0))
        echo "No changes from last audit report." >> $auditreport
    EchoAndLogMessage "Role audit report generated: $auditreport."
Init
EchoAndLogMessage "Starting EPMAutomate role audit report generation"
PostProcess
EchoAndLogMessage "EPMAutomate role audit report completed"
