Post-Installation Security Hardening
Introduction
After installation, the OC-CNE system security stance should be audited prior to placing the system into service. This primarily consists of changing credentials and sequestering SSH keys to trusted servers. The following table lists all the credentials that need to be checked / changed / retained:
Table 4-2 Credentials
| Credential Name | Type | Associated Resource | Initial Setting | Credential Rotation |
| TOR Switch | username / password | Cisco Top or Rack Switch | username/password from PreFlight Checklist | Reset post-install |
| Enclosure Switch | username / password | HP Enclosure Switch | username/password from PreFlight Checklist | Reset post-install |
| OA Admin | username / password | HP On-board Administrator Console | username/password from PreFlight Checklist | Reset post-install |
| ILO Admin | username / password | HP Integrated Lights Out Manger | username/password from PreFlight Checklist | Reset post-install |
| Server Super User (root) | username / password | Server Super User | Set to well-known Oracle default during server installation | Reset post-install |
| Server Admin User (admusr) | username / password | Server Admin User | Set to well-known Oracle default during server installation | Reset post-install |
| Server Admin User SSH | SSH Key Pair | Server Admin User | Key Pair generated at install time | Can rotate keys at any time; key distribution manual procedure |
| MySQL Admin | username / password | MySQL Database | Set by customer during initial install | Reset post-install |
If factory or Oracle defaults were used for any of these credentials, they should be changed prior to placing the system into operation. The customer should then store these credentials in a safe a secure way off site. It is recommended that the customer may plan a regular schedule for updating (rotating) these credentials.
Prerequisites
This procedure is performed after the site has been deployed and prior to placing the site into service.
Limitations and Expectations
The focus of this procedure is to secure the various credentials used or created during the install procedure. There are additional security audits that the CNE operator should perform such as scanning repositories for vulnerabilities, monitoring the system for anomalies, regularly checking security logs. These are outside the scope of this post-installation procedure.References
- Nexus commands to configure Top of Rack switch username and password:https://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus9000/sw/6-x/security/configuration/guide/b_Cisco_Nexus_9000_Series_NX-OS_Security_Configuration_Guide/b_Cisco_Nexus_9000_Series_NX-OS_Security_Configuration_Guide_chapter_01001.html
- HP commands to configure Enclosure switch username and password:https://support.hpe.com/hpsc/doc/public/display?docId=c04763521
- HP OA commands to configure OA username and password:https://support.hpe.com/hpsc/doc/public/display?docId=emr_na-a00040582en_us&docLocale=en_US#N101C8
- HP iLO commands to configure iLO username and password:https://www.golinuxhub.com/2018/02/hp-ilo4--cli-guide-cheatsheet-example.html
- See ToR switch procedure for initial username/password configuration: Configure Top of Rack 93180YC-EX Switches
- See procedure to configure initial iLO/OA username/password: Configure Addresses for RMS iLOs, OA, EBIPA
- See Enclosure switch procedure for initial username/password: Configure Enclosure Switches
Procedure
Table 4-3
| Step No. | Procedure | Description |
| 1.
Reset Credentials on the TOR Switch |
| 2.
Reset Credentials on the Enclosure Switch |
| 3.
Reset Credentials for the OA Admin Console |
| 4.
Reset Credentials for the ILO Admin Console |
| 5.
Reset Credentials for the root account on Each and Every Server | Login to each and every server in the
cluster (ssh admusr@cluster_host ) and perform the following command:
sudo passwd root |
| 6.
Reset (or Delete) Credentials for the admusr account on Each and Every Server | Login to each and every server in the
sudo passwd -l admusr |
| 7.
Reset Credentials for the MySQL Accounts | See Database Tier Installer for details on how to reset the DB Account Passwords. |
| 8.
Regenerate / Redistribute SSH Keys Credentials for the admusr Account | Log into the Bastion Host VM and generate a
new cluster-wide keypair by perform the following:
ssh-keygen -b 4096 -t rsa -C "New SSH Key" -f .ssh/new_occne_id_rsa -q -N "" Now, for each and every server in the cluster, perform these actions: # for each cluster_host in the cluster; do
# copy the public key to the node
scp .ssh/new_occne_id_rsa.pub admusr@cluster_host:.ssh/
# install the key
ssh admusr@cluster_host "cat .ssh/new_occne_id_rsa.pub >> .ssh/authorized_keys"
# done
At this point, the new key should be usable. Switch from using the old key to the new key, and confirm that each and every cluster host is still reachable. On the Bastion Host VM, perform these actions: # remove the old keys from the agent (assuming you are using an agent)
ssh-add -D
# add the new key to the agent
ssh-add .ssh/new_occne_is_rsa
# confirm access to the cluster host(s) and remove the old key
ssh admusr@cluster_host "sed -i '/ occne installer key$/d' .ssh/authorized_keys"
# done
The new private key (new_occne_id_rsa) should also be copied to any secondary Bastion Host VM, and possibly copied off site and securely saved. |
