Configure Enclosure Switches
Introduction
This procedure is used to configure the 6127XLG enclosure switches.
- Procedure OCCNE Configure Top of Rack 93180YC-EX Switches has been completed.
- Procedure OCCNE Configure Addresses for RMS iLOs, OA, EBIPA has been completed.
- The Utility USB is available containing the necessary files as per: Installation PreFlight checklist: Create Utility USB.
All steps are executed from a Keyboard, Video, Mouse (KVM) connection.
Procedure
Table 3-8 Procedure to configure enclosure switches
| Step # | Procedure | Description |
| 1.
Copy the 6127XLG configuration file |
Copy the 6127XLG configuration file from the Utility USB (See Installation PreFlight checklist : Create the OA 6127XLG Switch Configuration File) to the /var/lib/tftpboot directory on the Installer Bootstrap Host and verify it exists and the permissions. $ cp /media/usb/6127xlg_irf.cfg /var/lib/tftpboot/6127xlg_irf.cfg $ ls -l /var/lib/tftpboot/ total 1305096 -rw-r--r--. 1 root root 311 Mar 25 08:41 6127xlg_irf.cfg |
| 2.
Modify the switch specific values in the /var/lib/tftpboot/6127xlg_irf.cfg file. |
These values are contained at Installation PreFlight checklist : Create the OA 6127XLG Switch Configuration File from column Enclosure_Switch.
$ cd /var/lib/tftpboot
$ sed -i 's/{switchname}/<switch_name>/' 6127xlg_irf.cfg
$ sed -i 's/{admin_password}/<admin_password>/' 6127xlg_irf.cfg
$ sed -i 's/{user_name}/<user_name>/' 6127xlg_irf.cfg
$ sed -i 's/{user_password}/<user_password>/' 6127xlg_irf.cfg
| 3.
Access the InterConnect Bay1 6127XLG | Access the InterConnect Bay1 6127XLG switch
to configure the IRF (Intelligent Resilient Framework).
Note: On a new switch the user is presented with the following when connecting to the console and must type CTRL_C or CTRL_D to break out of the loop. Note: When trying to save the config, the following prompt is received: [HPE] [HPE] save The current configuration will be written to the device. Are you sure? [Y/N]: Before pressing ENTER you must choose 'YES' or 'NO'[Y/N]:y Please input the file name(*.cfg)[flash:/startup.cfg] (To leave the existing filename unchanged, press the enter key): User can leave this default startup.cfg unchanged, or change to another name. The cfg file will be used for next reboot. $ ssh <oa username>@<oa address> If it shows standby, ssh to the other OA address. OA-FC15B41AEA05> connect interconnect 1 .... <HPE>system-view System View: return to User View with Ctrl+Z. (Note: Run the following commands:) irf member 1 priority 32 interface range Ten-GigabitEthernet 1/0/17 to Ten-GigabitEthernet 1/0/20 shutdown quit irf-port 1/1 port group interface Ten-GigabitEthernet1/0/17 port group interface Ten-GigabitEthernet1/0/18 port group interface Ten-GigabitEthernet1/0/19 port group interface Ten-GigabitEthernet1/0/20 quit interface range Ten-GigabitEthernet 1/0/17 to Ten-GigabitEthernet 1/0/20 undo shutdown quit save irf-port-configuration active |
| 4.
Access the InterConnect Bay2 6127XLG |
Access the InterConnect Bay2 6127XLG switch to re-number to IRF 2. OA-FC15B41AEA05> connect interconnect 2 .... <HPE>system-view System View: return to User View with Ctrl+Z. [HPE] irf member 1 renumber 2 Renumbering the member ID may result in configuration change or loss. Continue?[Y/N]Y [HPE]save The current configuration will be written to the device. Are you sure? [Y/N]:Y Please input the file name(*.cfg)[flash:/startup.cfg] (To leave the existing filename unchanged, press the enter key): Validating file. Please wait... Saved the current configuration to mainboard device successfully. [HPE]quit <HPE>reboot Start to check configuration with next startup configuration file, please wait.........DONE! This command will reboot the device. Continue? [Y/N]:Y Now rebooting, please wait... System is starting... |
| 5.
Configure the IRF on Bay2 6127XLG switch |
After rebooting, the interfaces will begin with number 2 such as Ten-GigabitEthernet2/0/17, Ten-GigabitEthernet2/1/5. Run the following commands: system-view interface range Ten-GigabitEthernet 2/0/17 to Ten-GigabitEthernet 2/0/20 shutdown quit irf-port 2/2 port group interface Ten-GigabitEthernet2/0/17 port group interface Ten-GigabitEthernet2/0/18 port group interface Ten-GigabitEthernet2/0/19 port group interface Ten-GigabitEthernet2/0/20 quit interface range Ten-GigabitEthernet 2/0/17 to Ten-GigabitEthernet 2/0/20 undo shutdown quit save irf-port-configuration active |
| 6.
Run "reboot" command on both switches |
| 7.
Verify the IRF for the 6127XLG switches. | When reboot is finished, verify IRF is
working with both member and ports from previous two switches, which form IRF
to act as one switch now.
<HPE>system-view
[HPE]display irf configuration
MemberID NewID IRF-Port1 IRF-Port2
1 1 Ten-GigabitEthernet1/0/17 disable
2 2 disable Ten-GigabitEthernet2/0/17
[HPE]
| 8.
Configure the IRF switch with predefined configuration file. |
<HPE>tftp 192.168.20.11 get 6127xlg_irf.cfg startup.cfg startup.cfg already exists. Overwrite it? [Y/N]:Y Press CTRL+C to abort. % Total % Received % Xferd Average Speed Time Time Time Current Dload Upload Total Spent Left Speed 100 9116 100 9116 0 0 167k 0 --:--:-- --:--:-- --:--:-- 178k <HPE>system-view System View: return to User View with Ctrl+Z. [HPE]configuration replace file flash:/startup.cfg Current configuration will be lost, save current configuration? [Y/N]:N Now replacing the current configuration. Please wait ... Succeeded in replacing current configuration with the file flash:/startup.cfg. [<switch_name>]save flash:/startup.cfg The current configuration will be saved to flash:/startup.cfg. Continue? [Y/N]:Y flash:/startup.cfg exists, overwrite? [Y/N]:Y Now saving current configuration to the device. Saving configuration flash:/startup.cfg.Please wait... Configuration is saved to device successfully. [<switch_name>] |
