Getting Started with Spark Streaming
Before you can use Spark streaming with Data Flow, you must set it up.
| What is Different | Non-Streaming Run | Streaming Run |
| Authentication | Uses an On-Behalf-Of (OBO) token of the requesting user. OBO tokens expire after 24 hours, so this is not suitable for long-running jobs. | Accesses Oracle Cloud Infrastructure Object Storage using session tokens tied to the Run's Resource Principal. It is suitable for long-running jobs. |
| Restart Policy | Fails if the Spark runtime exit code is non-zero. | Restarts up to ten times if the Spark runtime exit code is non-zero. |
| Patch Policy | No patching policy as jobs are expected to last fewer than 24 hours. | Automatic monthly patches. |
Connecting to Oracle Cloud Infrastructure Streaming
Learn how to connect to Oracle Cloud Infrastructure Streaming.
- Set up Oracle Streaming Service and create a stream.Note
Oracle Streaming Service has the following limits:- Messages in a stream are retained for no less than 24 hours, and no more than seven days.
- All messages in a stream are deleted after the retention period has expired, whether they have been read or not.
- The retention period of a steam can't be changed after the stream has been created.
- A tenancy has a default limit of zero or five partitions depending on your license. If you require more partitions you can request a service limit increase.
- The number of partitions for a stream can't be changed after creation of the stream.
- A single stream can support up to 50 consumer groups reading from it.
- Each partition has a total data write of 1 MB per second. There is no limit to the number of PUT requests, provided the data write limit isn't exceeded.
- Each partition has five GET requests per second per consumer group. As a single stream can support up to 50 consumer groups, and a single partition in a stream can be read by only one consumer in a consumer group, a partition can support up to 250 GET requests per second.
- Producers can publish a message of no more than 1 MB to a stream.
- A request can be no bigger than 1 MB. A request's size is the sum of its keys and messages after they have been decoded from Base64.
- Add streaming policies to Data Flow.
- Use a plain password or auth token. This method is suitable for cross
environment quick testing. For example, Spark structured streaming
application prototyping, where you want to run locally and on Data Flow against the Oracle Streaming
Service. Note
Hardcoding, or exposing, the password in application arguments isn't considered secure, so don't use this method for production runs. - Resource principal authentication is more secure than plain password or auth token. It's a more flexible way to authenticate with Oracle Streaming Service. Set up streaming policies to use resource principal authentication.
A Java sample application and a Python sample application are available.
This is a sample Java application for Data Flow.
package example;
import org.apache.log4j.LogManager;
import org.apache.log4j.Logger;
import org.apache.spark.SparkConf;
import org.apache.spark.api.java.function.FlatMapFunction;
import org.apache.spark.sql.Dataset;
import org.apache.spark.sql.Row;
import org.apache.spark.sql.RowFactory;
import org.apache.spark.sql.SparkSession;
import org.apache.spark.sql.catalyst.encoders.ExpressionEncoder;
import org.apache.spark.sql.catalyst.encoders.RowEncoder;
import org.apache.spark.sql.functions;
import org.apache.spark.sql.streaming.StreamingQuery;
import org.apache.spark.sql.streaming.Trigger;
import org.apache.spark.sql.types.Metadata;
import org.apache.spark.sql.types.StringType$;
import org.apache.spark.sql.types.StructField;
import org.apache.spark.sql.types.StructType;
import org.apache.spark.sql.types.StructType$;
import org.apache.spark.sql.types.TimestampType$;
import java.sql.Timestamp;
import java.text.SimpleDateFormat;
import java.util.Arrays;
import java.util.concurrent.TimeoutException;
public class StructuredKafkaWordCount {
public static void main(String[] args) throws Exception {
Logger log = LogManager.getLogger(StructuredKafkaWordCount.class);
log.info("Started StructuredKafkaWordCount");
Thread.setDefaultUncaughtExceptionHandler((thread, e) -> {
log.error("Exception uncaught: ", e);
//Uncomment following line to enable debug log level.
//Logger.getRootLogger().setLevel(Level.DEBUG);
if (args.length < 4) {
printUsage();
String bootstrapServers = args[0];
String topics = args[1];
String checkpointLocation = args[2];
String type = args[3];
String outputLocation = null;
switch (type) {
case "console":
System.err.println("Using console output sink");
break;
case "csv":
if (args.length < 5) {
printUsage();
outputLocation = args[4];
System.err.println("Using csv output sink, output location = " + outputLocation);
break;
default:
printUsage();
SparkSession spark;
SparkConf conf = new SparkConf();
if (conf.contains("spark.master")) {
spark = SparkSession.builder()
.appName("StructuredKafkaWordCount")
.config("spark.sql.streaming.minBatchesToRetain", "10")
.config("spark.sql.shuffle.partitions", "1")
.config("spark.sql.streaming.stateStore.maintenanceInterval", "300")
.getOrCreate();
} else {
.master("local[*]")
.getOrCreate();
// Create DataFrame representing the stream of input lines from Kafka
Dataset<Row> lines = spark
.readStream()
.format("kafka")
.option("kafka.bootstrap.servers", bootstrapServers)
.option("subscribe", topics)
.option("kafka.security.protocol", "SASL_SSL")
.option("kafka.sasl.mechanism", "OCI-RSA-SHA256")
.option("kafka.sasl.jaas.config",
"com.oracle.bmc.auth.sasl.ResourcePrincipalsLoginModule required intent=\"streamPoolId:ocid1.streampool.oc1.phx.amaaaaaaep4fdfaartcuoi5y72mkrcg7hzogcx2jnygbmgik3hqwssxqa6pq\";")
.option("kafka.max.partition.fetch.bytes", 1024 * 1024) // limit request size to 1MB per partition
.option("startingOffsets", "latest")
.load()
.selectExpr("CAST(value AS STRING)");
// Split the lines into timestamp and words
StructType wordsSchema = StructType$.MODULE$.apply(
new StructField[]{
StructField.apply("timestamp", TimestampType$.MODULE$, true, Metadata.empty()),
StructField.apply("value", StringType$.MODULE$, true, Metadata.empty())
ExpressionEncoder<Row> encoder = RowEncoder.apply(wordsSchema);
final SimpleDateFormat dateFormat = new SimpleDateFormat("yyyy-MM-dd'T'HH:mm:ss");
Dataset<Row> words = lines
.flatMap(
(FlatMapFunction<Row, Row>) row -> {
// parse Kafka record in format: "timestamp(iso8601) text"
String text = row.getString(0);
String timestampString = text.substring(0, 25);
String message = text.substring(26);
Timestamp timestamp = new Timestamp(dateFormat.parse(timestampString).getTime());
return Arrays.asList(message.split(" ")).stream()
.map(word -> RowFactory.create(timestamp, word)).iterator();
, encoder);
// Time window aggregation
Dataset<Row> wordCounts = words
.withWatermark("timestamp", "1 minutes")
.groupBy(
functions.window(functions.col("timestamp"), "1 minutes", "1 minutes"),
functions.col("value")
.count()
.selectExpr("CAST(window.start AS timestamp) AS START_TIME",
"CAST(window.end AS timestamp) AS END_TIME",
"value AS WORD", "CAST(count AS long) AS COUNT");
wordCounts.printSchema();
// Reducing to a single partition
wordCounts = wordCounts.coalesce(1);
// Start streaming query
StreamingQuery query = null;
switch (type) {
case "console":
query = outputToConsole(wordCounts, checkpointLocation);
break;
case "csv":
query = outputToCsv(wordCounts, checkpointLocation, outputLocation);
break;
default:
System.err.println("Unknown type " + type);
System.exit(1);
query.awaitTermination();
private static void printUsage() {
System.err.println("Usage: StructuredKafkaWordCount <bootstrap-servers> " +
"<subscribe-topics> <checkpoint-location> <type> ...");
System.err.println("<type>: console");
System.err.println("<type>: csv <output-location>");
System.err.println("<type>: adw <wallet-path> <wallet-password> <tns-name>");
System.exit(1);
private static StreamingQuery outputToConsole(Dataset<Row> wordCounts, String checkpointLocation)
throws TimeoutException {
return wordCounts
.writeStream()
.format("console")
.outputMode("complete")
.option("checkpointLocation", checkpointLocation)
.start();
private static StreamingQuery outputToCsv(Dataset<Row> wordCounts, String checkpointLocation,
String outputLocation) throws TimeoutException {
return wordCounts
.writeStream()
.format("csv")
.outputMode("append")
.trigger(Trigger.ProcessingTime("1 minutes"))
.option("path", outputLocation)
.start();
}This is a sample Python application for Data Flow.
#!/usr/bin/env python3
from pyspark.sql import SparkSession, SQLContext
from pyspark.sql.functions import concat, col, current_timestamp, lit, window, \
substring, to_timestamp, explode, split, length
import argparse
import os
def main():
parser = argparse.ArgumentParser()
parser.add_argument('--auth-type', default='PLAIN')
parser.add_argument('--bootstrap-port', default='9092')
parser.add_argument('--bootstrap-server')
parser.add_argument('--checkpoint-location')
parser.add_argument('--encryption', default='SASL_SSL')
parser.add_argument('--ocid')
parser.add_argument('--output-location')
parser.add_argument('--output-mode', default='file')
parser.add_argument('--stream-password')
parser.add_argument('--raw-stream')
parser.add_argument('--stream-username')
args = parser.parse_args()
if args.bootstrap_server is None:
args.bootstrap_server = os.environ.get('BOOTSTRAP_SERVER')
if args.raw_stream is None:
args.raw_stream = os.environ.get('RAW_STREAM')
if args.stream_username is None:
args.stream_username = os.environ.get('STREAM_USERNAME')
if args.stream_password is None:
args.stream_password = os.environ.get('STREAM_PASSWORD')
assert args.bootstrap_server is not None, "Kafka bootstrap server (--bootstrap-server) name must be set"
assert args.checkpoint_location is not None, "Checkpoint location (--checkpoint-location) must be set"
assert args.output_location is not None, "Output location (--output-location) must be set"
assert args.raw_stream is not None, "Kafka topic (--raw-stream) name must be set"
spark = (
.appName('StructuredKafkaWordCount')
.config('failOnDataLoss', 'true')
.config('spark.sql.streaming.minBatchesToRetain', '10')
.config('spark.sql.shuffle.partitions', '1')
.config('spark.sql.streaming.stateStore.maintenanceInterval', '300')
.getOrCreate()
# Uncomment following line to enable debug log level.
# spark.sparkContext.setLogLevel('DEBUG')
# Configure Kafka connection settings.
if args.ocid is not None:
jaas_template = 'com.oracle.bmc.auth.sasl.ResourcePrincipalsLoginModule required intent="streamPoolId:{ocid}";'
args.auth_type = 'OCI-RSA-SHA256'
else:
jaas_template = 'org.apache.kafka.common.security.plain.PlainLoginModule required username="{username}" password="{password}";'
raw_kafka_options = {
'kafka.sasl.jaas.config': jaas_template.format(
username=args.stream_username, password=args.stream_password,
ocid=args.ocid
'kafka.sasl.mechanism': args.auth_type,
'kafka.security.protocol': args.encryption,
'kafka.bootstrap.servers': '{}:{}'.format(args.bootstrap_server,
args.bootstrap_port),
'subscribe': args.raw_stream,
'kafka.max.partition.fetch.bytes': 1024 * 1024,
'startingOffsets': 'latest'
# Reading raw Kafka stream.
raw = spark.readStream.format('kafka').options(**raw_kafka_options).load()
# Cast raw lines to a string.
lines = raw.selectExpr('CAST(value AS STRING)')
# Split value column into timestamp and words columns.
parsedLines = (
lines.select(
to_timestamp(substring('value', 1, 25))
.alias('timestamp'),
lines.value.substr(lit(26), length('value') - 25)
.alias('words'))
# Split words into array and explode single record into multiple.
words = (
parsedLines.select(
col('timestamp'),
explode(split('words', ' ')).alias('word')
# Do time window aggregation
wordCounts = (
words
.withWatermark('timestamp', '1 minutes')
.groupBy('word', window('timestamp', '1 minute'))
.count()
.selectExpr('CAST(window.start AS timestamp) AS START_TIME',
'CAST(window.end AS timestamp) AS END_TIME',
'word AS WORD',
'CAST(count AS long) AS COUNT')
# Reduce partitions to a single.
# Output it to the chosen channel.
if args.output_mode == 'console':
print("Writing aggregates to console")
query = (
wordCounts.writeStream
.option('checkpointLocation', args.checkpoint_location)
.outputMode('complete')
.format('console')
.option('truncate', False)
.start()
else:
print("Writing aggregates to Object Storage")
query = (
.format('csv')
.outputMode('append')
.trigger(processingTime='1 minutes')
.option('path', args.output_location)
.start()
main()Connecting to a Streaming Source in a Private Subnet
Follow these steps to connect to a streaming source in a private subnet.
Create a private endpoint if one doesn't already exist.
Set up Oracle Streaming Service and create a stream as described in Connecting to Oracle Cloud Infrastructure Streaming
Copy the streaming source FDQN to allow traffic between VNICs within the private subnet used to create Data Flow Private Endpoint. If the streaming source is in a different subnet to the Data Flow Private Endpoint, allow traffic between the Streaming subnet and Data Flow Private Endpoint subnet.
