Running Command Line or Silent Installations
Oracle Smart View for Office can be installed from the command line.
Additionally, administrators can enable silent installations—installations that do not require settings to be specified each time—for Smart View and Smart View extensions. The silent installation command can be included in scripts to automate installation.
Related Topics:
Before You Begin
Complete steps 3 and 4 in Installing from My Oracle Support or Oracle Technical Resources to download the Smart View installation zip file and unzip it to the folder you will be working in.
Oracle recommends ensuring that all Microsoft Office processes are terminated on the machines where a silent installation or upgrade will be running. In Windows Task Manager, the Office processes to check for and terminate are Excel, Word, PowerPoint, and Outlook.
Command Line and Silent Installation Options
Use the options in Table 2-3 to install Smart View from the command line and for silent installations.
Table 2-3 Options for Command Line and Silent Installations of Smart View
Option | Usage |
Specifies command line options to be passed to the Smart View MSI installer. For example, to specify the installation directory, use:
To enable logging, use:
Unless the |
Runs the Smart View installer in silent mode. The |
Specifies the installation directory.
Note: Oracle recommends installing in the default location or in a
location that does not contain any spaces in the
installation path. For example, Oracle advises that you do
not install in |
or
Enables logging.
Unless the Note: This command may be used with or without a blank space after
the initial |
Extracts the MSI file. |
Specifies the path to the extension installer:
For example:
Path to |
Uninstalls Smart View. Use this command to uninstall Smart View when it has been installed or upgraded using the command line or silent installer. If Smart View was installed using the wizard (described in Installing from My Oracle Support or Oracle Technical Resources), then follow the procedure in Uninstalling Smart View. |
The silent installer wrapper follows these rules:
It passes the value of the
/v
parameter intact to the MSI. -
The
/s
flag is converted to/qn
and passed to the MSI. There is no need to specify the/qn
parameter if/s
is already present in your script. -
Unless the
/v
parameter contains any/q
specifier, the wrapper passes/qb+
to the MSI.
Silent installations are only supported for admin users.
Installing Using Command Line or Silent Install Options
