Understanding the Installation and Upgrade Process
This documentation explains the process used to upgrade Release 9.2 software which consists of these steps:
  • Install the Deployment Server (see Concurrent Installation below for concurrent operations)
  • Install the Platform Pack (see Concurrent Installation below for concurrent operations)
  • Set up the installation plan by running Installation Planner
  • Run the Installation Workbench
  • Install the HTML Web Server
    A JD Edwards EnterpriseOne HTML Web Server is mandatory to run web-enabled JD Edwards EnterpriseOne applications, which includes all end-user applications and selected tools applications. This guide only describes the definition of the HTML Web Server in regards to the Installation Planner and the Installation Workbench. The installation of the HTML Web Server itself is not covered by this guide. Separate guides describe the separate installation process for the HTML Web Server on the supported platforms using Server Manager. Topics relating to the HTML Web Server other than installation using Server Manager are covered in platform-specific reference guides. Such topics include the installation and configuration of the underlying application servers.
    Refer to these JD Edwards EnterpriseOne guides which are available on the JD Edwards EnterpriseOne Documentation library. For Applications Release 9.2 and Tools Release 9.2.x, refer to this library on the Oracle Technology Network at this link:
    http://docs.oracle.com/cd/E61420_01/index.htm
  • Install the Development Clients for developers and system administrators
You can concurrently install the Deployment Server, the Platform Pack, and the HTML Web Server assuming the installation programs are run on different machines. This can decrease the overall time it takes to complete the upgrade.
Recommended Configurations
You can set up your Release 9.2 configuration in many ways. You should follow the typical setup and naming conventions whenever possible, unless there is a strong business case that supports the need to change.
See Also
Typical Customer Configuration in the JD Edwards EnterpriseOne System Administration Guide for more information about the typical customer configuration provided with Release 9.2.
JD Edwards EnterpriseOne Release 9.2 does not support coexistence.
If you have ever had JD Edwards World installed, you will need to perform the steps in JD Edwards EnterpriseOne Ending Coexistence Guide before starting your Release 9.2 upgrade.
This section discusses:
