Modifying and Using System Data Rules
If you want to use the delivered sample rules with your test data, you must perform the following steps:
  • Clone the rule using the Rules Engine Manager. The rule (s) can be accessed in this component and copied using the ‘Create New Rule from Rule’ feature.
  • Modify Rule Name and Descriptions.
  • You can change the Rule Category designation.
  • Modify the Rule Statements where Campus Solutions sample data is used (see the Rule Evaluation/Calculation table entries for each rule, above) using your data, your criteria and logic on so on.
  • Test the rule using the Rules Engine Manager Test feature.
  • Activate the rule.
See Understanding the Rules Engine
See Setting Up the Rules Engine
