Connecting to the TCSI System
To use the TCSI system, you need to set up Campus Solutions (CS) to connect to TCSI. Before you set up CS, make sure your organization is registered in PRODA.
You must use PeopleTools 8.57 or later.
This section describes:
Pages Used to Connect to the TCSI System
Page Name Definition Name Navigation Usage
Organisation
SSR_HM_ORG
Records and Enrollment, and then Enrollment Reporting, and then AUS Regulatory Reporting, and then TCSI, and then TCSI API Setup, and then Organisation
Enter the organization information Oracle gave you.
Devices
SSR_HM_DEVICES
Records and Enrollment, and then Enrollment Reporting, and then AUS Regulatory Reporting, and then TCSI, and then TCSI API Setup, and then Devices
Provide the device information you registered in PRODA.
Campuses API Test
SSR_HM_CAMPUS_GET
Records and Enrollment, and then Enrollment Reporting, and then AUS Regulatory Reporting, and then TCSI, and then TCSI API Setup, and then Campus API Test
Test whether your configuration is correct by retrieving a list of all your campuses in TCSI.
Errors API Test
SSR_HM_ERR_IMPORT
Records and Enrollment, and then Enrollment Reporting, and then AUS Regulatory Reporting, and then TCSI, and then TCSI API Setup, and then Errors API Test
Retrieve a list of all available errors from TCSI.
Services
IB_SERVICEDEFN
PeopleTools, and then Integration Broker, and then Integration Setup, and then Service Definitions
Update test URLs to production URLs.
Configuring Campus Solutions to Connect to TCSI
Access the Organisation page (Records and Enrollment, and then Enrollment Reporting, and then AUS Regulatory Reporting, and then TCSI, and then TCSI API Setup, and then Organisation).
Field or Control Description
Organization ID
Enter the ID you were assigned when you registered your organization in PRODA.
Organization Name
Enter the name your organization was assigned when you registered in PRODA.
Client ID
Enter the ID that Oracle provided to your organization. There will be different IDs for test and production.
Software Name
Enter the name that Oracle provided to your organization.
Oracle may provide your organization its own production client ID to minimize potential impacts from the TCSI call rate limit.
Providing Device Registration Details
Access the Devices page (Records and Enrollment, and then Enrollment Reporting, and then AUS Regulatory Reporting, and then TCSI, and then TCSI API Setup, and then Devices).
Use the Devices page to enter the B2B device registration details. For information on registering a B2B device, go to the PRODA website. Once your device is active, it stays active for six months. To renew your registration, generate a new code in PRODA.
Device Name
Enter the name of the B2B device you registered in PRODA. You can use separate devices for each environment.
Device Activation Code
Enter the unique activation code that PRODA gave you. This code is valid for seven days, and you’re responsible for remembering the code.
If you misplace your code or it expires, you can generate a new one in PRODA.
Auto-Refresh Keys n Days Before Expiry
Enter a number that’s used to determine when a new device key is automatically generated before the current key expires. If this date/time falls within the number of days from the current date, a new key is automatically generated. By default, this field is set to 3.
When you run a TCSI process, it checks the TTL value. If it falls within the “Auto-Refresh Keys n Days Before Expiry” window, 3 days from expiry as shown in the screenshot, a new PRODA device key is generated.
Activate Device
Note: This button is available only when you set up your B2B device in CS for the first time.
Click to switch on communication between CS and TCSI. This process establishes that the device and activation code are active. When you activate your device, PRODA sends a response with the expiry date and time of the device key. CS stores the expiry date and time, and uses this to determine when to automatically refresh your device key.
Refresh Device Key
Once you have activated your device, this button appears. When you renew registration, click to activate the new activation code you received from PRODA.
Note: When you specify a value in Auto-Refresh Keys n Days Before Expiry, CS automatically refreshes your device key for you. You would only use the Refresh Device Key process if you need to manually reactivate your device. In that event, you must get a new activation code from PRODA, enter the new activation code in Device Activation Code, and then click Refresh Device Key.
Authenticate Device
Click to authenticate your device’s connection with TCSI. This process establishes that you have a valid access token. When you run the TCSI Migration, Course/Campus, and Student Data processes, the processes will authenticate the device automatically as required.
The Campuses API Test and Errors API Test pages show that your device is authenticated.
Testing Your Connection
Access the Campuses API Test page (Records and Enrollment, and then Enrollment Reporting, and then AUS Regulatory Reporting, and then TCSI, and then TCSI API Setup, and then Campus API Test).
Use this page to test whether CS can connect to the TCSI System.
Once your device is authenticated, this page will show the authentication status, and you can click Get All Campuses to retrieve the list of campuses for your institution. In Response Message, the response from the TCSI system appears. To confirm whether the API call was successful, look in the second line for “success”: true.
Testing Your Connection to the Errors API
Access the Errors API Test page (Records and Enrollment, and then Enrollment Reporting, and then AUS Regulatory Reporting, and then TCSI, and then TCSI API Setup, and then Errors API Test).
When you run the TCSI Migration, Course/Campus, and Student Data processes, you may encounter a TCSI error. When this happens, the error ID is stored with the transaction ID in the SSR_HM_TX_ERROR table. If this is the first time you come across an error, the error message details are stored in the SSR_HM__ERROR table. Over time, TCSI may change the description, details, and resolution of errors. This page lets your institution refresh all error descriptions, details, and resolutions by calling the TCSI Error API endpoint. Once your device is authenticated on the Devices page, you can click Import All Errors to retrieve the list of TCSI errors.
Configuring the Integration Broker for TCSI/PRODA Endpoints
Access the Services page (PeopleTools, and then Integration Broker, and then Integration Setup, and then Service Definitions).
The PUM image is configured with the test URLs that point to the TCSI REST API endpoints. Once you’re ready to move to your production environment, you must update the test URLs to production URLs.
To update the URLs in Integration Broker:
  1. Navigate to the Services page.
  2. In Service, enter SSR_HEIMS.
  3. Select REST Service, then click Search.
  4. From the list of services, click SSR_HEIMS. You should see all the service operations that correspond to TCSI endpoints.
  5. In the list of existing operations, select a TCSI service operation.
  6. On the General page, in REST Base URL, update the value with the production URL, then click Save.
  7. Click Return to Service, then repeat steps 5-7 until you’ve updated all REST Base URLs.
Here’s the list of endpoints, their corresponding service operations, and their test and production URLs.
Endpoint Service Operations Test URL Production URL
aggregated-awards
AGGREGATED_AWARDS_DELETE
AGGREGATED_AWARDS_GET
AGGREGATED_AWARDS_PATCH
AGGREGATED_AWARDS_POST
https://test.api.humanservices.gov.au/centrelink/ext-vend/tcsi/b2g/v1/aggregated-awards
https://api.humanservices.gov.au/centrelink/ext/tcsi/b2g/v1/aggregated-awards
campuses
CAMPUSES_DELETE
CAMPUSES_GET
CAMPUSES_PATCH
CAMPUSES_POST
https://test.api.humanservices.gov.au/centrelink/ext-vend/tcsi/b2g/v1/campuses
https://api.humanservices.gov.au/centrelink/ext/tcsi/b2g/v1/campuses
courses
COURSES_DELETE
COURSES_GET
COURSES_PATCH
COURSES_POST
https://test.api.humanservices.gov.au/centrelink/ext-vend/tcsi/b2g/v1/courses
https://api.humanservices.gov.au/centrelink/ext/tcsi/b2g/v1/courses
courses-of-study
COURSES_OF_STUDY_DELETE
COURSES_OF_STUDY_GET
COURSES_OF_STUDY_PATCH
COURSES_OF_STUDY_POST
https://test.api.humanservices.gov.au/centrelink/ext-vend/tcsi/b2g/v1/courses-of-study
https://api.humanservices.gov.au/centrelink/ext/tcsi/b2g/v1/courses-of-study
courses-on-campus
COURSES_ON_CAMPUS_DELETE
COURSES_ON_CAMPUS_GET
COURSES_ON_CAMPUS_PATCH
COURSES_ON_CAMPUS_POST
https://test.api.humanservices.gov.au/centrelink/ext-vend/tcsi/b2g/v1/courses-on-campus
https://api.humanservices.gov.au/centrelink/ext/tcsi/b2g/v1/courses-on-campus
course-admissions
COURSE_ADMISSIONS_DELETE
COURSE_ADMISSIONS_GET
COURSE_ADMISSIONS_PATCH
COURSE_ADMISSIONS_POST
https://test.api.humanservices.gov.au/centrelink/ext-vend/tcsi/b2g/v1/course-admissions
https://api.humanservices.gov.au/centrelink/ext/tcsi/b2g/v1/courses-admissions
device activation
DEVICE_ACTIVATION_PUT
https://test.5.rsp.humanservices.gov.au/piaweb/api/b2b
https://5.rsp.humanservices.gov.au/piaweb/api/b2b
device authentication
DEVICE_AUTHENTICATION_POST
https://vnd.proda.humanservices.gov.au/mga/sps/oauth/oauth20/token
https://proda.humanservices.gov.au/mga/sps/oauth/oauth20/token
device key refresh
DEVICE_KEY_REFRESH_PUT
early-exit-awards
EARLY_EXIT_AWARDS_DELETE
EARLY_EXIT_AWARDS_GET
EARLY_EXIT_AWARDS_PATCH
EARLY_EXIT_AWARDS_POST
https://test.api.humanservices.gov.au/centrelink/ext-vend/tcsi/b2g/v1/early-exit-awards
https://api.humanservices.gov.au/centrelink/ext/tcsi/b2g/v1/early-exit-awards
errors
ERRORS_GET
https://test.api.humanservices.gov.au/centrelink/ext-vend/tcsi/b2g/v1/errors
https://api.humanservices.gov.au/centrelink/ext/tcsi/b2g/v1/errors
help-balances
HELP_BALANCES_GET
https://test.api.humanservices.gov.au/centrelink/ext-vend/tcsi/b2g/v1/help-balances
https://api.humanservices.gov.au/centrelink/ext/tcsi/b2g/v1/help-balances
loans
LOANS_DELETE
LOANS_GET
LOANS_PATCH
LOANS_POST
https://test.api.humanservices.gov.au/centrelink/ext-vend/tcsi/b2g/v1/loans
https://api.humanservices.gov.au/centrelink/ext/tcsi/b2g/v1/loans
notifications
NOTIFICATIONS_GET
https://test.api.humanservices.gov.au/centrelink/ext-vend/tcsi/b2g/v1/notifications
https://api.humanservices.gov.au/centrelink/ext/tcsi/b2g/v1/notifications
students
STUDENTS_DELETE
STUDENTS_GET
STUDENTS_PATCH
STUDENTS_POST
https://test.api.humanservices.gov.au/centrelink/ext-vend/tcsi/b2g/v1/students
https://api.humanservices.gov.au/centrelink/ext/tcsi/b2g/v1/students
units-of-study
UNITS_OF_STUDY_GET
https://test.api.humanservices.gov.au/centrelink/ext-vend/tcsi/b2g/v1/units-of-study
https://api.humanservices.gov.au/centrelink/ext/tcsi/b2g/v1/units-of-study
unit-enrolments
UNIT_ENROLMENTS_DELETE
UNIT_ENROLMENTS_GET
UNIT_ENROLMENTS_PATCH
UNIT_ENROLMENTS_POST
https://test.api.humanservices.gov.au/centrelink/ext-vend/tcsi/b2g/v1/unit-enrolments
https://api.humanservices.gov.au/centrelink/ext/tcsi/b2g/v1/unit-enrolments
Here are examples of updating Integration Broker URLs.
This example illustrates the fields and controls on the Service Operations page.
Example: Updating TCSI REST Endpoints with Production URLs
